Target Static compession on E85?
Old Nov 6, 2007 | 04:51 PM
Carnutz's Avatar
Default Target Static compession on E85?
Thinking about going "on the corn" with a 408 CI LSX, using either LQ9 heads that I have now or switching to L92 heads and the GMPP single plane.
What seems to be the ideal compression ratio when running E85? Do you want to have a higher compression ratio when going to E85 or stick with 8.2-8.7 static and turn up the boost???
Old Nov 6, 2007 | 05:35 PM
camaroandreas's Avatar
We usually use 9.0 compression up to 28-35 psi (on small import engines).
I really recommend E85, more power then VP csp and other racefuels..
Old Nov 6, 2007 | 06:50 PM
02SSLE's Avatar
Is it true about you have to move more volume with E85?
Old Nov 6, 2007 | 07:24 PM
smokinHawk's Avatar
ya i would do 9.0-9.7 but i havent run it yet and am just guessing
Old Nov 6, 2007 | 08:20 PM
02SSLE's Avatar
a wide band doesn't go down that low. How would you know?
Old Nov 6, 2007 | 08:22 PM
02SSLE's Avatar
is that also all you would change with the tune?
Old Nov 6, 2007 | 08:57 PM
Zombie's Avatar
A wideband doesn't care about ratio, only Lambda. Tuning for 14.7:1 AFR (lambda 1.00) on gas and then switching to E85 will still net you a stociometric mixture (lambda 1.00).
Widebands don't care what the fuel source is.
If I run 11.0:1 AFR on gas and then go e85 and still use the same wideband, I'd still target 11.0:1 AFR on the wideband and it would be the correct mixture. The wideband would just be displaying an incorrect AFR for the fuel but would still be correct because the lambda is the same.
Old Nov 6, 2007 | 09:05 PM
02SSLE's Avatar
what is lambda?
Old Nov 6, 2007 | 09:07 PM
MECHAM's Avatar
yes...you must add about 30% more fuel to the injector tables.
Old Nov 6, 2007 | 09:12 PM
02SSLE's Avatar
So do you know this first hand or are you quoting something that you read?
Old Nov 6, 2007 | 09:19 PM
BoostnTBSS's Avatar
9.7 Here and yes AFR gauges do go that low you just need to set it up for the right fuel. Just off the top of my head gas/14.7=E85/9.0
MECHAM's Avatar
https://ls1tech.com/forums/showthrea...&highlight=e85
read the negatives...have seen other non ls1 tuned...but imports with low impedance injectors. 1000+ cc's so they have enough injector to run it and high boost
Old Nov 7, 2007 | 02:24 AM
I will have 8pcs 160lb on my LSX engine..
Old Nov 7, 2007 | 06:23 AM
smokinHawk's Avatar
i thought we are talking about setting up the compression ratio for the engine, not the AFR
Old Nov 7, 2007 | 07:47 AM
Runn's Avatar
Yes... back to topic.
Old Nov 7, 2007 | 07:48 AM
ls1290's Avatar
Dumb Ass Vette Moderator
In general with NA applications, you have to run a lot more compression with ethanol than gas to achieve the same power level on similar setups. If you are going to run about 15psi, you can pretty easily run 10:1 static compression. That is the beauty of ethanol, is that it is highly resistant to pre-combustion detention.
Of course there is the down side in that you will have to run a lot more fuel. Gas requires 14.7 oxygen molecules to burn one, while ethanol is around 9 I believe.
Keith
Old Nov 7, 2007 | 08:02 AM
NA engine gives ~ 10% more power with E85 then pumpfuel. With the same compression..
Old Nov 7, 2007 | 10:50 AM
Carnutz's Avatar
I am aware of the added fuel delivery needed, and ~30% seems to be the magic number. IE BIG pump, lines and 160# Injectors....... I got that.
What I am after, is knowing that E85 will support, and works best with big compression (NA for example 14-15 to 1) Is it benifical to raise the static compression on a boosted application, or leave it low IE 8.5 to one and run more boost???
Just FYI there is a good thread in the Fueling section of this board dealing with the ins and outs of E85
Old Nov 7, 2007 | 01:10 PM
You don´t need to raise the compression with turbo. Just boost a little more..
Old Nov 7, 2007 | 01:32 PM
Runn's Avatar
My experience is a little lower around 5%... But i might be wrong.
