408 turbo build - need advice
Even though I am gonna with out a doubt go to a 408, it's gonna be hard to break down the stock rotating assembly with out having any fun on it. So I'm thinking about running it for a short while before i go all out. Any clue to how much a stock set up will hold?
There is a guy I know that is running twin 76's with a high compression ford motor with blow through.
I've found alot good info on putting a th400 behind my 6.0 but I'm still kinda in the dark about the flywheel. I keep on seeing that I need to run a certin size, but what size is that exactly?
Turbo's don't add very much heat to the engine compartment as long as you have a heat shield on the turbine housing and locate it properly. All OEM turbo cars have the turbo under the hood. Even after 25+ years, there is no significant difference in heat degradation of non-metallics in the engine compartments of these cars. What are you so worried about?
Mike
And Mike, thanks for your info and ur 2 cents but i ain't worried about nothin. I know I can put it in the engine compartment and I know all OEM cars turbos are mounted on the manifolds but mine ain't oem and I guess I'm just into "fads." I just like the remote systems, I have nothing against turbos mounted in the engine compartment, it's just what I want.
Mike
I mean yall have a very good point and another thing that is good about the set up is that I wont have to buy an expensive oil pump or a bunch of tubing to get back to the intercooler and intake.
1. Cheap.
2. Easy to install.
3. Doesn't clutter the already-tight engine bay.
4. Reaches their hp goals.
All are valid points, but most will readily admit that a front-mount will make more power and spool faster. The rest are delusional.
Mike
