Not LS1 but cool Hellion Twin kit with Eaton
#42
you need to remeber that the SC has no presure refferance to anything. all it does is MOVE AIR! the faster you spin it the more air it shifts. now one key factor is the air its sucking in. if there is a restriction before the blower, no matter how fast you spin it, the power will still be lower than without a restriction.
now move the other way. lets put positive presure on the intake side of the blower. and lets say for arguements sake its 14.5psi (1bar). now lets also asume that the SC will move twice the volume of air to the engines demands at WOT. therefore the boost form the SC (with no turbos) will be 1bar also.
so what happens when you put them together??? well you cant just say 14.5+14.5= around about 30psi. what you can say is the supercharger will move twice the air the engine needs. so it will move 2 lots of 14.5psi.
its more comlex than that as you have to think about efficies and stuff but thats basically what happening.
thanks Chris.
#43
i think the lancier (spell) S4 groupe B rally car ran the same idea.
thanks Chris.
#44
^Nissan actually made a production car engine with this.
It had a bypass valve in it like N4cer is talking about and the supercharger used an electric clutch like a A/C compressor.
Here's a link to the article. http://www.autospeed.com/cms/A_2216/article.html
#45
Wouldnt the supercharger compress the same amount as it did when it was fed by ambient air? Say, compressing the allready compressed air coming from the turbo/s? Not shure how to do the math on it, but say the supercharger boosted to 1 bar when fed by ambient air, then the turbo/s feed 1 bar worth of compressed air into it...wouldnt it compress that air at the same rate it did the ambient air?
#48
no it wont make 26 psi! you can just say it will make xxpsi because there are far to many veriables.
thanks Chris.
thanks Chris.
#49
IATs will be through the roof. Hellion used to claim 1100 rwhp with their 76mm single kit. Then everyone realized it was complete BS.
44psi and lifting heads, i wonder why. Anyone of the turbo companies out there could have bolted up their kits to the blower, but they realized it was reinventing the wheel and this is a gas motor, not a diesel that weighs 6000+ lbs that needs the extra torque to get it moving.
HPP with their twin kit was using 27psi and making 1050 SAE and 1048 Uncorrected. Id love to see their numbers under both circumstances as well as timing, fuel, etc...
Just my opinion of course.
#50
OWN3D BY MY PROF!
#53
thanks Chris.
#54
LS1Tech Sponsor
The funny thing is that the car is a 03 Cobra ,Saleen, with the Rainbow,mystic type of paint. I think its the only one they made.
#55
I think its like stuffing 10lbs of **** (two turbos) into a 5lb bucket (1 eaton) 44 psi is a huge restriction and maybe alot of detination because of high air temps because that little intercooler wasnt made to cool that much air. I dont know much but it looks like a joke to me.
#57
I recently saw a turbo'd cobalt SS results here http://www.srtforums.com/forums/showthread.php?t=337853. It picked up a ton of hp but not so much torque. Kinda unique though.
#58
The blower just seems to be a restriction (pressure drop) like an IC would have. It probably sees 44 psi between the turbos and blower.Then the 26psi is seen after the blower. The blower is just slowing things down and heating everything up.
#59
This concept is NOT the most efficient way to make peak power but will make an insane street experience.
The turbos make 26psi of boost after the air/air intercooler. The eaton takes this 26psi and increases it to 44psi after its air/water intercooler. There is a pretty decent tech story here http://www.musclemustangfastfords.co...bra/index.html
Now, you can definitely make this much power with turbos alone AND at a lower boost BUT you will not have the same type of response. It is hard to beat the nearly instant boost and linear throttle response of a positive displacement supercharger. This allows you to run large turbines for excellent exhaust flow, get the instant supercharger response AND go way higher than the SC alone power capacity. Sounds like serious fun to me.
