Building a block for FI
Old Nov 27, 2007 | 03:16 PM
kp's Avatar
kp
I just took my 347 apart after nearly two years of beating it up pretty well. Crank and main/rod bearings look great. As expected the pistons are about done. Thats around 350 passes and I never showed it much mercy thats for sure. It still ran fine though and I took it out because I felt it has served its purpose, not because anything was wrong with it. Matter of fact leakdown was still very good, had no blowby and the same oil pressure it had the day I started it for the first time. I could have ran it for another season with the D1 I'm sure.
Old Nov 27, 2007 | 06:56 PM
ALL UC2's Avatar
i would go with a iron block 370 with good rods and pistons......but stock crank.guys on here putting down more than you are asking for reliably........i have about the same goals as you and thats what im planning on using.....
