TT GTO Project
Old Nov 27, 2007 | 03:00 PM
TrakDay's Avatar
Default TT GTO Project
POST # 55 and 56 have more pictures
Well I blew up my F1C Procharger Head Unit over a year and a half ago now and I am finally back to working on the car again.
This was the first F series procharged GTO in the country... I loved the setup but felt like it was never going to go as fast as I wanted to go with room to grow even more. So I tore the whole car down after blowing up the F1C.
I tore the rear end and start the SRA conversion which at the time was the 3rd SRA conversion on a GTO, but many more have been done by shops now. Though mine was done in my garage with a couple of buddies...
Anyways here is a list of the setup and whats to come for the car along with pictures...
Engine:
Iron 408 9.0:1 compression- Callies lightened crank and much more
ETP 240cc Heads with the works
EDC Custom Grind Cam
Turbo Kit:
Twin GT42R turbos
Custom Twin Turbo Kit - Stainless Steel
JGS 50mm WGs
JGS 56mm BOVs
Twin A2W Intercoolers
Electronics:
TurboSmart E-Boost 2
Autometer Nexus Fuel PSI and Wideband A/F Gauges
Big Stuff 3
RacePak Dash
Fuel:
Weldon 2025
-10 Braided Feed Line
Speed Inc Black Fuel Rails
-8 Return Line
Aeromotive Pro Series Regulator
Pre and Post Filters
Transmission:
Built TH400 Short Tail
B+M Shifter
Transbrake
Precision 4400 Stall
Rear End:
Carbon Fiber Driveshaft
Moser 9" SRA
3.50 Gears
35 Spline Axles
BMR Torque Arm
BMR Lower Control Arms
BMR Panhard Rod
HAL QA1 Double Adjustable Coilovers
Custom Fabbed Brackets for Entire Rear End
Front Suspension:
STOCK
ARP Studs
Brakes:
Upgraded Rotors x4
Upgraded Pads x4
Upgraded SS Lines x4
Interior:
10Pt Custom Roll Cage
Corbeau FX1 Blk/Red Seats x2
Gutted Interior
4Pt Safety Harness
No AC
No Heat
So that is basically whats going into the car or what is already there. I may be leaving some stuff out, but I will update this section as I remember more.
September 14, 2007:
Car dropped off at shop, trailered the car in from Jax Thursday night.
The car is completely tore apart with only interior carpet, dash, door panels and a custom Moser 9" SRA in the car. Nothing else!!! The wheel well are still cut out and have yet to be welded back in after adding the additional space for the mini-tubs, the motor is out of the car, the TH400 is out of the car, and the interior is mostly guttted along with no front bumper on the car.
Pictures to follow...
This is how I dropped the car off...
The SRA conversion... complete other than the custom sway bar thats being made!
Interior loaded with boxes of parts...
Wheel wells opened up...
Empty engine bay...
TrakDay's Avatar
September 20, 2007 UPDATE
Pictures of the 408 with ETP240cc heads!!! The boxes bumper and tranny are all for my car as well...
Old Nov 27, 2007 | 03:01 PM
TrakDay's Avatar
Update: 10 - 17 - 07
The engine bay has been emptied of every accessory that we do not need along with all of the brake lines and all other lines. The main wiring harness will be coming out of the car next.
The engine bay is painted and the 408 is in the car along with the new solid motor mounts! Next step is getting the Twin GT42R turbos here and begin fabbing the manifolds up!
Now for the pictures...
Before cleaning/painting the engine bay...
After paint...
Motor In...
Solid Motor Mounts...
TrakDay's Avatar
Just a small update. Here's a picture of the new custom radiator. They did a real nice job on it. We needed something that was a bit shorter so we could put in our intercoolers.
Here's a picture of the radiator in the car. We need to make some custom brackets for it.
here's a pic of the radiator next to the stock one. It's quite shorter.
We had the rear end narrowed and we got it back in the car. The deeper wheels looks cool. These are the "street" tires. 325/50/15 radials.
Old Nov 27, 2007 | 03:04 PM
Zombie's Avatar
man, that looks really expensive.
TrakDay's Avatar
Finally got around to cleaning up and painting the rear end and components...
Here is the IC in its fabrication stages... It was 2 intercoolers, we cut the endtanks of each and welded a single midtank so there is one pipe going to the TB. A2W obviously!
The twins that are going to make it all happen... GT42Rs... MMMM
And another better picture of the new short radiator!
Old Nov 27, 2007 | 03:08 PM
Speed Density's Avatar
hashtagBMW
Looking good!
Tony.
Photochop's Avatar
No kidding. Wow...wish I had that deep of pockets.
Old Nov 27, 2007 | 03:13 PM
TrakDay's Avatar
Well I spent the last year and a half acquiring parts for the build and just started the build around September! So its not like I bought everything at once. I do have all of the MAJOR parts though, so no more big money expenses on parts... by big money I mean 2k plus! Other than my Bogarts and slick set for the track!
Old Nov 27, 2007 | 03:27 PM
1INSANEGTO's Avatar
Damn race cars!!!!! Put the A/C back on the and go AirtoAir *****
Old Nov 27, 2007 | 04:18 PM
Photochop's Avatar
Thats badass man I'm sure it'll be a blast once it's done. Looks like a nice collection of good parts thatll work well together. Only thing I'm wondering about is taht 4400 converter. Better be a VERY tight 4400 with those turbos and the torque they're gonna be making.
Old Nov 27, 2007 | 04:54 PM
SSilverSSurfer's Avatar
damn thats a straight race car. im loving it thought, i remember when you talked about this glad to see its finally coming around
Old Nov 27, 2007 | 05:07 PM
sprayjunkie's Avatar
Will this be the first torque arm GTO?
Either way, its a sick setup....
Old Nov 27, 2007 | 05:11 PM
High Pressure's Avatar
That is a bad *** setup!!!!!!!!!
Old Nov 27, 2007 | 05:12 PM
TrakDay's Avatar
2nd Torque Arm GTO... The guys that helpd me do it did one of theirs before mine! So technically the 3 of us did the first and second torque arm GTOs and 1st and 3 SRA GTOs in the country!
Old Nov 27, 2007 | 05:13 PM
TrakDay's Avatar
It worked great on the F1C Procharger... but I can send it back to Precision and get it restalled for free so its no biggie, we will just have to wait and see if we need to make the change or not
Old Nov 27, 2007 | 05:24 PM
allthrotle's Avatar
X2
Old Nov 27, 2007 | 06:54 PM
Tiago's Avatar
very nice build. Congrats
Old Nov 27, 2007 | 07:00 PM
Phil99vette's Avatar
7 Second Club
Project is coming together nicely.
Phil
Old Nov 27, 2007 | 07:44 PM
Kingsize's Avatar
Awsome work bro, nice to see some hardcore goats being built finally.
