Any Warhawk block users in here?
Old Dec 2, 2007 | 09:28 AM
Jake@EPP's Avatar
Originally Posted by Big Bird WS6
so bob would you say that the warhawk block is better or worse then the LSX block? or how does the new L92/LS3 block?
thanks bob
Honestly, to answer that right now, we would have no clue. Only time will tell with the huge stress of racing it. If we bang a cylinder, rip it out and slap a new liner in, top fuel style
Old Dec 2, 2007 | 09:44 AM
EPP's Avatar
EPP
We have used both the World Products Warhawk block and the LSX block, both our built tough. We do like the way World Products incorporated the additional two head bolt holes, they look much stronger. Bob
World Products Warhawk block shown above
LSX block
Old Dec 3, 2007 | 01:19 AM
chuntington101's Avatar
off topic but bob do you know what the weight differance is for a built LSX block compeared to the Warhawk?? also at what point would you yourself start to recomend that people 'upgrade' to one of these blocks??
thanks
CHris.
Old Dec 3, 2007 | 04:52 AM
EPP's Avatar
EPP
I don't know the weight difference off hand. I'm going to guess that it is 100 or so pounds.
If you're looking at pushing past 1000 rwhp then these blocks should be looked at. Bob
Old Dec 3, 2007 | 09:21 AM
onfire's Avatar
Coal Mining Director
A 3.90" bore LSX weighs 225lbs....so some weight would be removed if it was bored to say 4.125" (possibly 15-20lbs) so guess 205lbs.
Warhawk block weighs 133 lbs.
~ 72 lb penalty for the LSX block. But it's built like a tank.
Old Dec 3, 2007 | 10:57 AM
nmp27's Avatar
Other F3 pix:
This one has ran 6.2x over at tulsa a few times
Bob, are you going after the record for the fastest procharger car?
Good luck, should be a wild ride!~
Old Dec 3, 2007 | 07:25 PM
EPP's Avatar
EPP
Thumbs up
Originally Posted by nmp27
Other F3 pix:
Looking good!!
Yes, that is what we are shooting for. The new chassis is being built, the Warhawk block will soon be on it's way, a lot to do in the next couple of months! It is going to be a busy year coming up for us! Bob
Old Dec 3, 2007 | 08:31 PM
Vertigo's Avatar
Holly mother of Gaw'd!!! It's a warp core!
Old Dec 3, 2007 | 11:55 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Or a flux capacitor. How ever you prefer to refer to it.
Old Dec 4, 2007 | 12:54 AM
Tom@SpeedInc's Avatar
Originally Posted by onfire
What's the price of the bare block and the LS7 heads
One consideration you may want to look into, World LS7 heads are setup for a head porter, so you may tie up considerable funds in having them ported.
ETP can make their heads with warhawk bolt pattern.
Old Dec 4, 2007 | 01:01 AM
ssswagon's Avatar
So can AllPro & Arao.
J
Old Dec 4, 2007 | 01:56 AM
  #32
MIEric's Avatar
Would it be possible to weld the extra material onto an LS1 / LS2 or even a 6.0 truck block...then drill the holes and helicoil it? Would be a way cheaper alternative to an aftermarket block if you allready had the block the welder and the materials...
Old Dec 4, 2007 | 04:27 AM
  #33
EPP's Avatar
EPP
It has been done before, the block is still going to not be as strong as these newer blocks, as they are beefier all the way around. Bob
Old Dec 4, 2007 | 10:18 AM
  #34
MIEric's Avatar
Cool, Im not so much worried about block strength as Im worried about blowing gaskets / pushing a ton of water.
Old Dec 4, 2007 | 11:55 AM
  #35
sr71bbjr's Avatar
You like the world products bolt locations?? The lsx top boss is closer to the cylinder and keeps material around the lifters.Not to mention the bolt on the world setup that goes through the intake runner! I like both blocks but i dont see how the bolt locations look better on the world block.
LSX block
Old Dec 4, 2007 | 12:03 PM
  #36
kp's Avatar
kp
I'm just waiting to see if GM releases an aluminum version of the LSX. Warhawk is a nice looking block and if you need 6 bolt aluminum right now you have little choice.
But IMO at those power levels I would be having an extra set of motor plates made up for a BBC Bob
Old Dec 4, 2007 | 03:42 PM
  #37
sr71bbjr's Avatar
Old Dec 4, 2007 | 04:44 PM
  #38
OWN3D BY MY PROF!
I'd be interesting in seeing the thermal affects of welding on aluminum and the resulting possible distortion.
Old Dec 5, 2007 | 04:58 AM
  #39
EPP's Avatar
EPP
Thumbs up
We decided to use All Pro heads on our build, they're building them to our spec's since we will be running on alcohol. Bob
By Brett Foote | 2026-06-04 05:00:17
