BMR Turbo style high-clearance K-member will not work with APS twin F body kit
Old 11-29-2007, 04:48 PM
Darren P's Avatar
Exclamation BMR Turbo style high-clearance K-member will not work with APS twin F body kit
I am in the middle of my install and I just found out that the BMR Turbo style high-clearance K-member will not work with the APS twin turbo kit for the F Body
I know this qustion came up on at least one other thread here so I wanted to post this up
BMR is sending me the correct K member as soon as it can be powder coated
I was trying to have the car running by this weekend for a local cruise in that I go to but it was not ment to happen
Oh well such is the fun of modifying a car
Old 11-29-2007, 05:09 PM
peter@aps's Avatar
Why did you think that the high clearance K member would fit?
Peter
Old 11-29-2007, 07:12 PM
Darren P's Avatar
I did not know if it would fit or not. I asked the people at BMR when I got the k member and they said it would fit. I had thought that in a year or 2 I may build my own twin kit and the extra room would be nice,
Old 11-29-2007, 07:16 PM
peter@aps's Avatar
How would they know unless thya have done a twin turbo install? The entire twin turbo system was developed around the regular K member so it does not surprize me in the least to hear that the system does not fit with the high clearance K member.
Good luck with your install,
Peter
Old 11-29-2007, 07:42 PM
Darren P's Avatar
I know
I am just posting this so someone will not make the same mistake that I did
that is all
Old 11-29-2007, 08:34 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Peter
geez,enough attitude?last time i checked this was an informative forum.Darren is just giving those who will/are/thinking about buying your kit a heads up thats all.
Old 11-29-2007, 08:57 PM
frcefed98's Avatar
I know
that is all
I took it that way too Save some people some headaches if they were thinking the BMR Turbo K member "might be a lil better" for this set up.
Good post Darren
Old 11-29-2007, 09:18 PM
GrannySShifting's Avatar
have pics of the kmember?
Old 11-29-2007, 09:22 PM
Darren P's Avatar
uploading them right now
Old 11-30-2007, 06:18 AM
2001WS6Vert's Avatar
It makes sense that a turbo car might use a turbo K-member. It is thoughtful to try and help others from making this mistake.
Old 11-30-2007, 06:28 AM
Firechikn's Avatar
That's weird. I would have thought the turbo kmember would have more room also. What part is touching? Good post for others.
Old 11-30-2007, 07:37 AM
smokinHawk's Avatar
yes what parts had clearance problems?
Old 11-30-2007, 07:55 AM
y2khawk's Avatar
I'm going to guess it's the box for the rear a arm mount. Just like all the regular tubular k members hit with the Incon kit.
Old 11-30-2007, 08:08 AM
MIGHTYMOUSE's Avatar
Darren will you be returning the k member to bmr?
If you do tell them I call 'dibbs' on it.
Old 11-30-2007, 01:04 PM
Darren P's Avatar
PM sent
Old 11-30-2007, 01:28 PM
No Juice's Avatar
Has anyone tried the regular UMI K-member? I believe they have two as well now.
Old 11-30-2007, 01:29 PM
Darren P's Avatar
where the outer twin bars were straight on the standred on and the High clearance one is curved
that is right were the discharge pipes from the turbo needs to go
on the driver side you may be able to work around it but the passanger side it actually hits the turbo and the triangle shaped hole is to small to fit the rubber tube through
Old 11-30-2007, 01:42 PM
smokinHawk's Avatar
you cant reclock the turbo?
anyways how big of a pipe can you fit in there?
can you fit a 5" in there?
Old 11-30-2007, 01:43 PM
qqwqeqwrqwqtq's Avatar
No help with the APS but their is certainly room for a downpipe on either side with the a/c in place
Old 11-30-2007, 01:54 PM
Darren P's Avatar
it does give a lot of room around the AC
but with the APS if you re clock it you still can't get around the piece
I guess you could make new turbo to intercooler pipes and make it work
Quick Reply: BMR Turbo style high-clearance K-member will not work with APS twin F body kit
