i have a fan???
Old Dec 2, 2007 | 09:20 PM
Rickys S/C Z28's Avatar
Default i have a fan???
i have a 9 in fan and an going to use it as a pusher fan, how do you guyss think it will work?? i am going to leave the ATI fans on and just but the spon on the other side
Old Dec 2, 2007 | 09:32 PM
DeltaT's Avatar
IMHO it will be more of a restriction than a help. What's the rest of your cooling setup?
Since you're in Hawaii, you should be able to get away with 100% distilled water and the right amount of Water Wetter, which should help lower temps ~20-25 degrees if you are running the factory coolant ratio now.
Jim
Old Dec 3, 2007 | 02:16 AM
i have a becool rad and a sphon fan when i cut the ATI shroud i cut it to low so i could not get the blower back in, so i put it on the other side(front) of the rad, cool thing is that its going to be blowing right into the hole i cut out, so im going to have 1 fan(ATI) behaind the rad and one in front of the rad! i think it will work but im not for sure, guss ill find out
Old Dec 3, 2007 | 04:01 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I assume you are running no a/c right? Or are u talking about mounting the fan on the a/c condensor or in between the a/c condensor and radiator? I am missing something here.
Old Dec 3, 2007 | 04:54 AM
EPP's Avatar
EPP
Ricky, throw some pic's on here so we can visualize it. Thanks. Bob
Old Dec 3, 2007 | 11:46 AM
TS6's Avatar
TS6
Its not going to work very well. The hole you cut in your shroud is causing the existing fan to pull air through it, and not through the radiator like it should. If I'm understanding you, you wanted to put the 9" fan next to the ATI fan like many others have done, but you cut the hole for it too low and it hits the blower, right? The best solution is to just make another shroud out of aluminum like the ATI shroud. Its flat and should be really easy to duplicate. Either that or make a patch panel and mount the fan where it needs to be. FWIW, I tried what you are attempting and even used a bigger fan (14") and it didn't work for ****.
Old Dec 3, 2007 | 01:08 PM
yes i still have A/C and i plan on running it in front the A/C condensor
will do when i get home from work
you hit the nail on the head that what im trying to do, but i have a back up plain if it does not work out then im going to do as you said
thanks for all the help guys!
Old Dec 3, 2007 | 09:52 PM
I run a Spal in front of the a/c condensor as well.
Old Dec 4, 2007 | 01:11 AM
and it works well?
Old Dec 8, 2007 | 01:15 AM
and it works well?
It sure does.
