best turbo to replace 76GTS?
J
if you're wanting a street car and not wanting to go all out, you'll absolutely love the 76GTS! my problem with it is i've got too many cubes for the 76 to work efficiently. basically the turbo is choking the motor. before the a/w intercooler, my inlet temps would start around 85* before the burnout and end up around 160* by the end of the 1/8th. i can keep the temps down w/ the new intercooler, but it's just a bandaid. i know a T6 would be my best bet, but i just don't have the room and don't really want to redo everything since i'm already building a track only car. just looking for a little more out efficiency out of this setup since the other car won't be finished for a year or two.
now i wish somebody would make plastic mock up turbos to rent out!
My 76GTS is absolutely crammed in there on the turbine side. I do have room for a bigger compressor scroll. The problem is that the 76 is a lot of power in a very small package, so it's hard to improve upon it.
The closest anyone has come is the ST80, which will support about 200 more hp, but I understand it's about the same size as the GT42 and PT88.
I got a little excited when I saw this:
some special gt-45 with a nonsponser link
. . . but then saw where the only downpipe attachment available is 5".
Mike
Mike
My boost was 19psi and a max timing of 18 degrees. I use to shift the car at 6100 but since swapping to the .96 a/r housing have been able to up that to 6700 on 15psi but haven't tried 20psi yet (power was still climbing on 15psi).
I think if you look real hard and test some pressures, you'll find a bottleneck in your combo.
Mike
Mike
Anthony
Mike
