Anxious for the weekend...
Old Dec 11, 2007 | 10:26 AM
ls1408cp's Avatar
what rpm do you think they will start spooling on your 427. I was thinking about doing twin 76s but a big single looks easier. good luck
Old Dec 11, 2007 | 01:12 PM
kp's Avatar
kp
I'd be pretty anxious for the weekend myself, I'm sure that thing will make some serious power
Old Dec 11, 2007 | 06:06 PM
venom ws7's Avatar
wow man after seeing that pic I'm anxious about this weekend too we wanna see some result ASAP.
Good luck.
Old Dec 11, 2007 | 06:19 PM
qqwqeqwrqwqtq's Avatar
Are we gonna see a 1500rwhp dyno sheet?
Old Dec 11, 2007 | 06:49 PM
Tiago's Avatar
Talking
eventually I hope so. For now I will have three walbros pushing the 96 lb injectors... so 1250 is probably all it will do....I knew I should have gone ahead and gotten the 160s
the MPT70s were sold .... that is why I went ahead and upgraded
Old Dec 11, 2007 | 07:35 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's going to be insane. I can't see how you plan on getting traction. You're going to need to be rolling around on slicks all the time unless you plan on supra style roll races.
160's are for race cars, just try to run your 96's at 5bar base
Old Dec 11, 2007 | 09:50 PM
ls2 bait's Avatar
how about pics of the whole setup
Old Dec 11, 2007 | 09:52 PM
Tiago's Avatar
Talking
100 psi under boost
pump flow would be falling off fast
If you search for my threads you will find pics of the entire setup.... I'll post a new one once the turbos are on it.
Old Dec 11, 2007 | 09:53 PM
JMBLOWNWS6's Avatar
Thats kick *** Tiago Cant wait to see the results!
Old Dec 11, 2007 | 10:44 PM
DrTurbo's Avatar
LS1TECH Sponsor
Tiago, swap to the 120lbs injectors.....idle better then the 160's and will handle more power then the 96's. Great compromise
Old Dec 11, 2007 | 11:15 PM
  #32
ls1408cp's Avatar
who makes 120s?
Old Dec 11, 2007 | 11:24 PM
  #33
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by ls1408cp
who makes 120s?
I think SD is the manufacture.
Old Dec 11, 2007 | 11:25 PM
  #34
100 psi under boost
Yes I'm sure the flow drops substantially, though we did just make 921rwhp with dual walbros @ 5bar base with no hint of a problem.
Also have 2 T400 cars with nearly 900rwhp on dual walbros @ 5bar that ran all season with no issues.
I did forget about the 120's Dr.Turbo speaks of though.
Old Dec 11, 2007 | 11:31 PM
  #35
DrTurbo's Avatar
LS1TECH Sponsor
Have you guys tried a triple pump setup yet? I am wondering how that works and its worth doing.
Old Dec 11, 2007 | 11:34 PM
  #36
ninetres's Avatar
All in the bucket????
Old Dec 12, 2007 | 12:27 AM
  #37
Inspector12's Avatar
TT-TECH Veteran
100 psi under boost
It falls off after 80PSI, but you can work around that Tiago. I am with Jim and Dr Turbo on the 120's. Good luck! Did you ever get your suspension checked out with that clunking noise? Was the TA coming loose or what?
Old Dec 12, 2007 | 12:33 AM
  #38
MECHAM's Avatar
i am running 3 walbro 255's in my 98. 2 on all the time..and the 3rd controlled by a boost/voltage regulator. been doing so for awhile now...i know...i know. pics are coming..shop has the car and i told them to take pic cause MM was wanting to see it.
Old Dec 12, 2007 | 07:30 AM
  #39
MIGHTYMOUSE's Avatar
damn right, cuz i am still on two walbros, 3 bar base w/ 96#ers no voltage booster
Old Dec 12, 2007 | 08:07 AM
  #40
Tiago's Avatar
Talking
I don't see why it wouldn't work, vipers and supras have done it for years. I will trigger my third pump from the EBOOST2 aux output
Ive already modified the bucket and the Y to tie in the third pump, should be easy....
I will try to raise the fuel pressure, why not
