A "new" turbo option for those of you want a GT47-88 but have physical size limits...
First the turbine wheel is larger....96mm vs 92, and the compressor cover difuser space is almost .5" larger which the S88 and S91 are within .05" of a full frame unit. Part of the reason why they don't suffer as much. Also the BW's use a larger diameter backing plate.
Kyle
LS1Tech Sponsor
Keep on arguing the point all you guys want. A full out 42 frame vs. a full out s400 frame and the BW unit will own! Thats that, take the best and bolt on the other and you will see. On a smaller cube motor its not such a huge issue. Get above 300 cubes and you will see.
