durability of injectors, reg, pumps with meth
what is the durability of all of the fuel system parts when using meth? talking alcohol rated pumps, injectos, reg. can you leave the meth in the system just like gasoline or will everything die.
most people i ask say the stuff can't take it and it needs to be flushed after each day of racing.
one guy a was talking to at the track was running in the 7's with no intercooler and 16 meth injectors. he told me they never did any extra maintainance. 3 years on the same pump, injectors, reg and no failures. this was an all out race car but i wouldn't think that would make any difernce since the important question here has to do with the corosive effect of meth and if it will kill the fuel system parts without flushing after each race day.
soo, what do you guys know.
FWIW, from what I have seen, it is more benefitial to run an intercooler AND methanol injection vs slightly more boost that can be had by running no intercooler as you will be limited by the possibility of detonation with the higher IAT's from more boost and less cooling ability with no intercooler.
Kurt
kurt- i'd be more than happy to give you a seasons worth of tuning methanol efi knowledge in exchange for knowledge with an lsx motor build for this season.
Kurt
if we run duel fuel we wont turn the meth pump/pumps on till maybe 70kpa and start spraying those injectors at ~100kpa. at idle and cruise they shouldn't be running. maybe have a fuel presure switch that makes sure the rails are primed and up close to presure at all times but not runing the pumps unless above a certain kpa in the intake.
Kurt
thats what i was talking about. kick it on at lets say 5inchs of vacume but not ask for any fuel from the injectors till more like 3psi. give it a window of time to get presured up. it would be kicking on quite a bit but not on at idle or cruise.
thing is if you punch it from a 30 roll and it downshifts it can go from high vacume to high boost prety fast, even with a somewhat laggy turbo. i could see it having presure but just kooking the fuel in the rails and leting it boil where it shows presure but is really just a bunch of air and still take some time to purge itself.
what about a fuel cooler of some kind? i know on our fairmont project the fuel gets hot. maybe all fuel gets hot and have just never had a fuel cell before where i could fell how hot it was. definately seems like a bad thing.
just mix some 104 unleaded in 15% with the alcohol for some 'sneaky punch' e85 and it will keep your fuel system straight.
I do run fuel coolers on both fuel tanks in the Nova. I sank two trans coolers in my water tank for the intercooler, the return fuel cycles back to the tanks after they pass through the coolers. It has worked well on two Power tour trips and one Drag week.
Kurt
