Budget 6.0l boosted build up Questions
Hey Guys i recently got my hands on a 6.0l long block It's an almost New LQ4<900miles on it>
Give me some ideas on what i need to do to make this thing survive with 12psi of boost
Also what would everyone recommend for a streetable Cam that would compliment the Procharger i have
what should my parts list include while i have the engine out?
I got a quote on a over bore to a 370ci ish motor with forged pistons and rods and all the other stuff <bolts gaskets>and a custom cam for $4600.00 is that too much?
I need your input on a good combo
thanks![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
jim
thanks
jim
define other stuff.
if that includes the head work sound like great deal, I guess it would also depend on the quality of the parts they're putting in it.
That Price includes no Head work stock Unmoleasted heads .Other stuff would be All gaskets assorted arp bolts and assembly and a balance resurface crank and blueprint balance block
I'm just not sure if it's such a good deal
jim
jim
I need you input on a good combo
jim
thanks
jim
6.0 bare block: $600 (new from GM)
6.0 stock crank: $100 (used from 01+ truck)
Machine work: $1000 (sonic, boring, o-ring, balance, assembly short block)
Pistons/rings: $500 (diamond)
H-beam rods: $400 (eagle)
cam: $400 (comp cams)
ARP head studs: $150
Heads: $1000 (used ARE stage II 6.0 heads)
head gaskets: $100 (cometic)
For your heads, Patriot is giving a good price on ported heads with larger valves. TEA is another good choice.
