Big Problem Formulating... =[
Old Dec 30, 2007 | 12:08 AM
Gordon0652's Avatar
Yeah i had a feeling...
I was looking into 1000rwhp with a 4000 stall and some good tires!
I was hoping that might get me there and if it didnt i would be happy with where it got me and if i am not i just might build the engine stronger and spray (nitrous) as soon as i get pasted the 60'.
There is just sooooo many variables to play around with it makes it hard.
Old Dec 30, 2007 | 12:09 AM
slow67's Avatar
Gingervitis Addict
I would personally run an S480 with the 1.32 T6 housing
Old Dec 30, 2007 | 10:46 AM
DrTurbo's Avatar
LS1TECH Sponsor
A ST80 will be working hard to make those #'s on a 408 due to the exhaust flow. Backpressure may become an issue. If you are wanting instant spool then its the right turbo as it will get you close to your #'s and spool like a raped ape. If you want a better mix, then step up to the SX80 with a race cover, as it will still be a T4 and have a better mix of spool and top end. The S88 will flat out get stupid at 25lbs.....your looking at more then 1100rwhp....S91, well that will be warp speed.
Old Dec 30, 2007 | 10:47 AM
DrTurbo's Avatar
LS1TECH Sponsor
We build those as well, but unmodded BW's don't spool as nicely, but still are decent units. Just don't spin them real hard un-modded....they will come apart. But on a V8 app, the shaft speed is not an issue yet.
Old Dec 30, 2007 | 10:57 AM
Gordon0652's Avatar
Alright thank you for all the info and opinions.
I need to rethink about this turbo set up; get some goals with a more appropriate turbo and turn thoes goals into a plan!
