A 396 Procharger Which Cam
Old Jan 4, 2008 | 09:49 AM
protwin's Avatar
Default A 396 Procharger Which Cam
I am steping up from a 383 to a 396 fully fordged motor with trick flow heads factory intake and body. I was running 12.6 lbs boost
@ 6100 and made 602 rwhp and 564 ft lbs tq. my cam specs were Comp Cam 233/239 cam – duration@.050” - .569/.577 lift, Comp Cam springs Comp Cam Pro Mag 1.6 roller rockers/guide plates – non-self aligning Com Cam lifters. Is this a good blower cam or do i need to change.
Old Jan 4, 2008 | 10:11 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The lift and durations look good. What is the LSA?
Keith
Old Jan 4, 2008 | 10:35 AM
BLNLS1/RX7's Avatar
THe best thing you could do is to contact Bob at Exotic Performance Plus.com.They sell and install more ProChargers than anyone.
Old Jan 4, 2008 | 01:10 PM
DeltaT's Avatar
If the LSA is 112 or greater it should make a primo blower cam. ~114 would be perfect IMHO.
Jim
Old Jan 4, 2008 | 06:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
The cam will work but it matters what the car is being used for. A basic Cam I run in 402-427's is a 234/240 on 115 XER.Real nice driver and I would expect 720-760hp /680-720tq depending on gas and tune with 12-13lbs of boost.I like stock drivability.
Old Jan 5, 2008 | 09:31 PM
eb02z06's Avatar
This man know's his stuff!!!!
Old Jan 7, 2008 | 02:33 PM
protwin's Avatar
Default cam
I am using this car for a drag/ride around and raise hell
Old Jan 7, 2008 | 06:45 PM
JPH's Avatar
JPH
put it on a 115LDA with a 112ICL, you will be happy.
Old Jan 8, 2008 | 08:27 AM
Brent@LPE's Avatar
I have been seeing Good gains on motors over 383 C.I. with stuff in the 235/245 114* I just haven't nailed one down enough to put our name on it. Should have another to test in the next week (14-16 #s)
Brent
Old Jan 9, 2008 | 10:22 PM
real82it's Avatar
I just spec'd out a similar motor (383 though, not 396).
comp cams suggested these cams:
For more street:
Comp Cams 07-467-8
576/570, 230/236, 113 lsa
Little more aggressive with less streetability:
Comp Cams: 07-468-8
584/579, 242/248, 113 lsa
Old Jan 13, 2008 | 03:55 AM
DeltaT's Avatar
I have a Comp solid roller 230/236 on 112LSA in my blown 383 and love it.
For the new 434 (moving the blower and heads over from the 383) I got a Comp solid roller 242/248 on 115LSA, but I haven't fired it up yet. That's the cam I chose based on advice from a few guys here and the Comp Tech. I wanted something that would not run out of cam until 6600-6800 with maybe 9# of boost.
Jim
