Spool difference between pt101 and 106
I know some of the New 106mm Turbos have revised wheels to help with the spooling issue. Those turbos are not cheap at all. The older 101-106mm turbos are some slow spooling suckers, but when they come on line they get NASTY fast.
I would still be worried about the stock crank, I am more of the type to try and do things only once though so I don't have to pay again.
You'll NEED more spring to handle any serious boost. I'd also think you'd need more cam to get the power up higher were you'll need it. Valvetrain is not the place to go bargain basement.
You really dont need anythng bigger than a 91 for that power range and you still have room for another 400 hp or so.
How much bigger is a 101 over a gt47-88?
