Spool difference between pt101 and 106
Old Jan 12, 2008 | 02:16 AM
ls1408cp's Avatar
Default Spool difference between pt101 and 106
I dont think there would be much of a spool difference but I thought i would ask before i bought one. I am about ready to start buying stuff and the nitrous motor is now out of the car.
Old Jan 14, 2008 | 12:43 AM
ls1408cp's Avatar
bump some recent pics
Old Jan 14, 2008 | 01:56 AM
sr71bbjr's Avatar
love the formula drag car look..Makes me miss mine..It's funny cause i think TA's look like ****..Dont get to over welmed when you make your list and buy all those parts and then make the next list and relize your still 30k away!!lol I finally said **** it! My cars been down for 4 yrs and alls i know is when it's running it's something i will be happy with!
Old Jan 14, 2008 | 03:11 AM
ls1408cp's Avatar
i am going cheap on the motor. i wont have more then 4k in it complete. The turbo stuff all added up does get expensive. I am doing everything else top notch so later when i do a expesive motor everything else will be good to go already. The car is already setup except for a 25.5 and chute. It only has a 6 point in it now.
Old Jan 14, 2008 | 12:29 PM
Mr.MartyStone's Avatar
Go 106 and don't look back. There's guys going fast in 326 and 360cid ferd motors with the 106. May want to try starting a thread on the turbo forums as those guys see a lot more thumper setups and know what truly works. Don Bailey would also be a good person to talk to.
Marty
Old Jan 14, 2008 | 01:07 PM
ls1408cp's Avatar
Don Bailey told me to do a 106mm
Old Jan 14, 2008 | 01:10 PM
Websy21's Avatar
If looks could kill, that thing will be sick. Waht ci are you going with?
Old Jan 14, 2008 | 02:25 PM
ls1408cp's Avatar
370 to start
Old Jan 14, 2008 | 03:19 PM
SSilverSSurfer's Avatar
damn i cant imagine how you feel. my cars been down 8 months and i cry everytime i see a stock fbody driving around, but youre right im going to be happy too once its done.
Old Jan 14, 2008 | 03:28 PM
RAGENZ28's Avatar
What's the width of your rear and what tire/rim combo are you running, it looks nice, +1 on the 106, anything with that under the hood is pretty damn cool.
Old Jan 14, 2008 | 04:45 PM
ls1408cp's Avatar
I cant remember exactly. I thi the wheels are 10 wide with a 5inch back spacing. The rear is narrow almost 8 inches or right over 8 inches i cant remember. Midwect chassis did all of it with the tubs.
Old Jan 15, 2008 | 05:08 PM
ls1408cp's Avatar
I bought a pt106, 60mm WG Tial and bov today. I also bought all the flanges I ned for it. Time to get started.
Old Jan 15, 2008 | 07:37 PM
88GT&69ss's Avatar
what a/r on exh housing on that 106?
Old Jan 15, 2008 | 07:40 PM
Phil99vette's Avatar
7 Second Club
Car looks bad *** fo sho!
Old Jan 16, 2008 | 12:52 AM
ls1408cp's Avatar
1.0 I was told it doesnt cost much to change the ehaust housing for when I do a bigger LSX
Old Jan 16, 2008 | 07:33 AM
88GT&69ss's Avatar
What C.I. engine will you be running?
Old Jan 16, 2008 | 09:21 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
So what your research come up with so far about running a 106mm with a 370ci LSx engine, will it work? Do folks think you can keep the rpms below say 7000, 7500, or 8000 rpms and still make all the power? I bet folks are advocating 10:1 compression.
Old Jan 16, 2008 | 09:59 AM
Josh@KY-Turbo's Avatar
My experience with a 101-106mm Turbo is that you need 1 of 2 things with a limited cube engine. 1) Compression to spool the turbo down low. Or 2) RPM to use the boost up top for power.
I know some of the New 106mm Turbos have revised wheels to help with the spooling issue. Those turbos are not cheap at all. The older 101-106mm turbos are some slow spooling suckers, but when they come on line they get NASTY fast.
Old Jan 16, 2008 | 10:03 AM
88GT&69ss's Avatar
I was just wondering but 1.0 is probably about right on that 106. When i got my 106 for my coupe it came with a 1.32 a/r boy that was a mistake on 348 c.i.!
Old Jan 16, 2008 | 10:05 AM
88GT&69ss's Avatar
Spooling does not seem to be a big issue when i started using a 3 step
