Paranoid about turning up the boost
Old Jul 4, 2003 | 11:43 AM
AlienDroid's Avatar
Default Paranoid about turning up the boost
I'm at 3psi right now running rich. I want to turn it up a bit but I'm worried about the MAF limitations.
If anyone knows about tuneing I have some questions.
When you are running rich, does that mean the PCM thinks there is more air flowing in then there is or is the reading from the MAF constant and unchangeable at a particular airflow?
What's the highest you would go without another tune?
8.8:1cr, 42.5 lb/hr with racetronix fuel pump, t76 turbo. Stock heads and cam.
thanks
Old Jul 4, 2003 | 03:32 PM
VINCE's Avatar
Shorty Director
Default Re: Paranoid about turning up the boost
Whats the particulars of your setup? You say stock heads and cam. Your shortblock must be different..
Old Jul 4, 2003 | 04:46 PM
AlienDroid's Avatar
It's a fully built bottom end with the 6.0l block. I know the cam should change but I'll do that later. I want to turn it up to 6 psi for the first time from about 2.5-3 psi, I'm just wandering if I should get a tune first or if I should worry about the PCM, the car is a 1998.
Old Jul 4, 2003 | 06:23 PM
VINCE's Avatar
Shorty Director
Ummmmmmm.. I would say GET IT TUNED FIRST!!!!! Taking a chance would only set you back 5k...
Old Jul 4, 2003 | 10:20 PM
QuickSilver2002's Avatar
Do you have a scanner. Pretty easy to see if the MAF maxes out with EFI live....
5lbs of boost would probably max the MAF readings on that motor (not sure at what rpm). Anyway, get it on a dyno and use the PE table to keep it in a safe AF range. Remember, FI = tuning, lots of tuning
