Autometer fuel/ boost gauge problem
Old Jul 5, 2003 | 02:50 PM
urslooow's Avatar
Default Autometer fuel/ boost gauge problem
I'm running the ati P-1 SC on my C5 coupe daily driver. Power was pulled from an accessory a/c 10amp fuse (there is another 20 or 30 amp fuse for the a/c also). When I turned on a/c it just blinked and went out (normal freon, normal compressor check at dealer). The fuse block was changed and it fixed the problem. Now 1 month later same problem. Could the problem be pulling power for the autometer fuel pressure gauge? Could I pull power from another fuse without causing a problem? My SC installer Breathless said they always pull power from this fuse with no problems. Does anyone know how to get in touch with Autometer? thyanks guys
