Silicone couplers?
Old Jan 14, 2008 | 04:07 PM
94blownz281's Avatar
Default Silicone couplers?
Does any company make a coupler for the LT1 that connects to the TB? i need to replace my metal intake tube(vortech unit) and would rather not spend the money on it or a trick flow. LS1-LS2 motors i have seen on here have something like what i'm talking about.
Old Jan 14, 2008 | 04:20 PM
SSilverSSurfer's Avatar
try
siliconhoses
hightempsilicone
Old Jan 15, 2008 | 06:25 AM
ls 2 goat's Avatar
also look at intakehoses
Old Jan 15, 2008 | 06:42 AM
KraZy's Avatar
do NOT use High Temp Silicone
I used them several years ago with great success but I ordered a reducer this summer and I have yet to recieve the item. I am unable to contact them either.
Old Jan 15, 2008 | 07:02 AM
smokinHawk's Avatar
i think i have heard they HTS went out of business or something, allot of people are having problems with them now.
Old Jan 15, 2008 | 02:36 PM
DeltaT's Avatar
Check turbohoses if you can't find a sponsor. They have adapters that may work...
Jim
Old Jan 15, 2008 | 03:35 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
What is the perimeter of the LT1 TB? You could use any round silicone coupler I would think and just squish it to form around the oval LT1 TB I would think. Just measure the perimeter and then divide it by pi and that should get you the diameter of an equivalent circular hose. I ordered all my couplers from siliconeintakes
Old Jan 15, 2008 | 04:05 PM
well vortech says its a 4" coupler. there is soft and easy and squash to the oval shape. thanks i will check out those places guys. hmm years ago i bought couplers for HTS.
Old Jan 15, 2008 | 06:40 PM
Jimmy P's Avatar
Do NOT order from them. We ordered about $100 worth of hoses/clamps,and the credit card charge went through, but they didn't send anything. If they are out of business, then why are they still accepting payments. We had to dispute the charge with the CC company.
Old Jan 15, 2008 | 09:19 PM
DMH Fabrication's Avatar
nonsponser url pimping is a no-no here
if you are interested in becoming a sponser please pm the appropriate people
Old Jan 15, 2008 | 09:52 PM
jamnut's Avatar
Originally Posted by 69vette
blah blah blah
One more vote for them. I have 2 turbo vehicles that I've done FMIC's on & used them for both cars, I think that every time I've ordered through them they shipped the same day.
Old Jan 16, 2008 | 11:54 AM
will the hose beable to handle boost blowing through it though? i'm suprised i'm the only one to want to do this?
69vette - how long is the coupon good for?
Old Jan 16, 2008 | 12:44 PM
CALL911's Avatar
Silicone may slide off under moderate to high boost conditions. I use a rubber hose that under enough boost eventually started to come off as well. I ended up fixing this by having a metal bead line welded on the TB for the hose to have something to hang on to when clamped.
Old Jan 16, 2008 | 02:00 PM
okay. well atleast now with your picture guys can see what metal elbow i mean. thanks guess i will have to buy another metal elbow then.
Old Jan 16, 2008 | 02:03 PM
PS call911- are you still using the stock radiator?
Old Jan 16, 2008 | 02:18 PM
CALL911's Avatar
Yeah, stock ratiator, stock waterpump, and it runs nice and cool
Old Jan 16, 2008 | 02:27 PM
i got rid of my stock radiator with only 30,000miles on it. i figured i would get something alittle better. i would like to move it forward as well as its easier to work on the blower.
Old Jan 16, 2008 | 02:31 PM
CALL911's Avatar
Most guys seem to have overheating issues when running the stock radiator. Mine has over 90,000 miles on it, and it still keeps my blown motor nice and cool. I'm not sure why I have success when so many others have issues, but I did have to move my radiator a little forward for room between it and the 12 ribbed blower belt, and upgrading to an aftermarket radiator definatly will help aid in cooling and fitting issues.
Anyways, good luck on the coupler.
Old Jan 16, 2008 | 03:27 PM
the discount code should be good forever... there is not an expiration date or anything
Old Jan 16, 2008 | 06:06 PM
hellbents10's Avatar
LS1Tech Sponsor
Again do not order from high temp silicone!!!!!!!
