Which rods for 1800hp?
Old Jan 23, 2008 | 07:19 PM
93formto98T/A's Avatar
Originally Posted by WAHUSKER
I thought the Eagle rods were all made with metal from China now? (= weak)
I was under the impression that the eagle stuff has been made overseas now for years...
Old Jan 23, 2008 | 07:55 PM
88GT&69ss's Avatar
either way they seem to hold up quite fine! Have them in my coupe... last dyno session we bumped the boost up to 24 psi and made over 1300 to the wheels on our mustang dyno. Im sure we are nearing the limits. but we keep the rpm down to 7200. Just my .02c
Old Jan 23, 2008 | 08:03 PM
wow, very impressive. Which rod bolts are you running? BTW I had eagle rods/l19 bolts in my TT TA so I am by no means bashing them. I was actually strongly considering using them for this build but I would rather pay a little more now for billets than be chancing my investment when I crank her up to 1700 or so.
Old Jan 23, 2008 | 09:42 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Dyer 300m
9000rpm and around 2xxx hp to date!!
Tom
Old Jan 24, 2008 | 11:00 PM
GueSS Who's Avatar
No one has said Lunati billet rods........Whatever hp level on a billet rod. I use lunati and no problems. I have used these same rods now in 5 motors.
Old Jan 25, 2008 | 12:49 AM
JBrady's Avatar
I too have always thought Carrillo tops. That said I have heard arguments that an "I" beam is stronger than the "H" beam found in Carrillo (and their copies like Eagle).
I recommend Speed-Talk for some excellent high end advice. Here are some failed Carrillos from a Supra turbo application. Check out the post for more info and argument.
http://speedtalk.com/forum/viewtopic...rrillo+failure
Old Jan 25, 2008 | 05:37 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Local Hayabusa's old Carrillos:
Seriously, this shouldn't even be a contest. Granted some of these rods people have named can take the power, but if you want the best your going to use aluminum. This is a tube chassis land speed car, not a street car driving thousands of miles a year.
Old Jan 25, 2008 | 06:29 PM
cracker's Avatar
Oliver's in the HPP Landspeed Cobra.
Old Jan 25, 2008 | 08:41 PM
Shawn @ VA Speed's Avatar
I said Lunati billets at the beginning of the thread 9000 rpms and 2500hp they have also seen 202 in the 1/4
