vacuum hobb switch?
Old Jul 7, 2003 | 12:09 PM
88ls1blazer's Avatar
Default vacuum hobb switch?
does anyone make, or know where to get a hobb switch that turns on at 4in of vacuum and lower? i need it for a dual pump fuel system to activate a second pump before boost is created so the fuel will be at the rail when i start to make boost, thanks, Andy
Old Jul 7, 2003 | 05:07 PM
99GMC Can's Avatar
Default Re: vacuum hobb switch?
Try and find a catalog. I'm sure they make adjustable ones
Old Jul 8, 2003 | 06:24 PM
they make adjustable, but they are designed to turn on and off at a given differntiation, like if it is set to turn on at one and the differntiation is 2, then it will turn back off at 3
Old Jul 9, 2003 | 06:36 AM
smokinHawk's Avatar
i only found a 5si or higher one for about $27
at 574-722-2097 dans performance or something.
Old Jul 9, 2003 | 03:59 PM
trackbird's Avatar
www.wicksaircraftsupply.com
Try them....(not sure, but they are a good place to start).
