1000hp radiator for a street car?
1300? Complete 600 to 700 for a radaitor? If you guys are interested PM me what you want.
I designed mine for 1000rwhp@++++
Pics are located at https://ls1tech.com/forums/pontiac-gto-2004-2006/851211-custom-radiator.html
I can get them for alotttt cheaper then $1300.00 complete with radiator, shroud, dual Spal fans to top it off there built to your specs.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I've got the cheap griffin from summit too. Cut the support and stood up. I did buy some high flow fans made with a molded shroud, probably in the 300 buck range. I had to cut and fabricate to make them fit the back of the radiator, but I haven't had any problems. I think the fans flow in the 4500cfm range together. Once they kick on, they only run for a minute at a time. I think they're only 3" thick.
