hiding a front mount
Old Jan 26, 2008 | 03:21 PM
01boydws6's Avatar
Default hiding a front mount
is there anyway to hide a front mount intercooler, I just got a 01 ws6 with a d1sc procharger and it has a big front mount intercooler so the front plate holder is gone and the fog lights to let airflow to it, problem is I live in a state where you have to have a front plate. Is there a way to mount the plate back up and still get enough air through the cooler??? I was thinking of fabing up some aluminum to direct the air through the fog light holes through the intercooler but will that be enough????
Old Jan 26, 2008 | 03:27 PM
Drew04GTO's Avatar
Just put the plate up on your dashboard. I too live in a state where a front plate is required. I have never been pulled over for no front plate and even got a speeding ticket 3 days ago and the cop didn't say anything. Really, i'm staying without the front plate until I get a ticket for it.
Old Jan 26, 2008 | 03:30 PM
Spade's Avatar
I have seen some on here that have mounted there plate to either side of the opening for the intercooler. You could try putting it on your dash. Really just depends on the how **** the cops are in your area.
Old Jan 26, 2008 | 04:35 PM
DeltaT's Avatar
To hide it, you can lightly spray it with Eastwood Radiator Black. It really helps make it disappear and won't hurt its efficiency.
Jim
Old Jan 26, 2008 | 05:56 PM
studderin's Avatar
mount it flat to the ground. it will still work fine
Old Jan 26, 2008 | 06:33 PM
01LS1Trooper's Avatar
drill speed holes in your plate
Old Jan 26, 2008 | 06:51 PM
52172's Avatar
exactly mount it horizontal. That how the hi-flo kits were designed and there is a post floating around here in the last ten days with excellent pics of the whole install on a TA.
Old Jan 26, 2008 | 07:48 PM
CALL911's Avatar
I have a large FMIC on my car, and it works well but you'd never be able to tell that by looking at it.
What I successfully did was cut out the area behind my foglights, and then I fabbed up a metal sheet that directed air from underneath the front bumper to the FMIC. It isn't as efficient as having the gaping hole in the front bumper like some do, however it still works as my IAT's are nice and cool. Granted my Camaro fron end is a much different design than your WS6, but you should be able to do the same concept with the plate underneath as I did.
Old Jan 26, 2008 | 07:50 PM
slow's Avatar
look at what the aps kit does.
Ryan
Old Jan 26, 2008 | 08:11 PM
ninetres's Avatar
-1 on the horizontal idea
Elementary physics mistake if you ask me.
Old Jan 27, 2008 | 10:24 AM
01boydws6's Avatar
would it get enough air just through the fog light holes if i directed the air through the holes and then from the bottom with some sheet metal and just put the front plate cover back in the middle????Any body have pictures of their front mount on their t/a or camaro???
Old Jan 27, 2008 | 10:29 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I did the horizontal method on mine. Works great
https://ls1tech.com/forums/forced-induction/832386-horizontal-fmic-project.html
Old Jan 27, 2008 | 11:20 AM
B18CYA's Avatar
I powder coated the one on my GSR. IAT temps were just fine @ 18psi so I dont think it effects it as much as people think
Old Jan 27, 2008 | 12:35 PM
CALL911's Avatar
It depends on how much you are in need of controlling your IAT's to keep you away from detonation. Mine works just fine with just a little air from the fogs, and more directed air from below. Again, this will not work as well as having a gaping hole would, but it will work. If you need more, methanol injection is an excellent way to help things as well. Some people just go with meth and no inetercooler, however running both is most effecient.
BTW, if you want more pictures, I can post them, but since I don't have a gaping hole in my bumper, theres not a whole lot to really see.
Old Mar 26, 2008 | 09:23 AM
transamws6baby's Avatar
I will be running the same set-up you are and I also live in a state where you must display a front plate. I was planning on bending my plate over just so the numbers are showing and maybe even drilling a couple holes in it where the dash is between the numbers and then mounting it to my intercooler. I dont know if the locals will give you a problem with this. Technically you are still displaying a plate and it is readable
Old Mar 26, 2008 | 09:49 AM
H21surfer's Avatar
The car was designed to get all the air from under the bumper.
Hint: that is why there is a big plastic flap under the car. It might not be as good as a huge hole cut out of the grill, but it works just fine for most people. It looks a lot better also.
All you can see, on my setup, is a little bit of the corners. I am sure it will work the same on a TA.
Old Mar 26, 2008 | 10:36 AM
ChevyChad's Avatar
Looks even better on a T/A
Can't even see it!
But its there!
Old Mar 26, 2008 | 11:32 AM
black01_WS6's Avatar
or you can find someone that has their twin 4.5 intercoolers that want to switch to a large fromt mount and just swap them and you will be able to hide evrything. just a thought.
Old Mar 26, 2008 | 04:48 PM
chewy99ws6's Avatar
I have mine mounted a little farther back so I still have my fog lights and I can put my front plate back in for that stealthy look but 99% of the time I leave the plate off
Old Mar 26, 2008 | 08:44 PM
brandon619's Avatar
I'm not an F-body but here is my picture.
