What rockers and lifters??
I have checked the torque on the rocker arms many times to make sure that they are all tight and have found no up or down movement, but plenty of side to side movement on the shaft, could this be causing the tick that I'm hearing? It's mostly on the driver side of the car and is quite loud if you put you head down behind the front tire.
I have checked many times for exhaust leaks as well and have found none. The warmer the car gets, the louder the noise is, it doesn't go away. I can hear something in the header tubes, but can't make out what it is. My cam is exhaust biased with 226/234 duration 598/599 lift on a 117 lsa, it's not a mild cam, but not that aggressive either.
This is driving me crazy, it didn't make this much noise with the stock exhaust manifolds and broken valve springs before the maggie install. It's not in the blower, nor is it imcompatibility, just noticed it after the blower install, and it sizzles my sac. The block is a TSP prepped forged 347 that had about 7k miles on it when I bought it, and I have since put about another 4.5k on it, and changed the oil three times, it sat for the last six months while I was in Iraq, so I changed it when I got back.
I was thinking about upgrading to some Yella Terra rockers, or something like that, should I also consider some new lifters as well, and which ones? Any and all help is greatly appreciated.
You need to ensure your lifter pre-load is correct. If its too little, then it will tick forever....well, until a pushrod falls out or breaks.
So now a dumb question, refresh my memory on how to check the lifter preload.
The cam that came out of the car for the maggie was an MTI Stealth II so I'm not sure if the base circle was a different diameter or not. I notice the noise mostly on the driver side, it seems more pronounced there and not as loud on the passenger side.
