My build - Lots of pics
Sean
The Callies Dragon Slayer crank
Callies Ultra H beam rods
And lastly the PRC heads
There is a little work to be done to the heads still, then it can finally all get assembled. The next project will be moving the car and all the tools to Chris's house though. That should be a fun filled weekend of work...
Sean
We eventually built the trans, and changed the rear gear to better suit our needs. We had some trouble with parts while building the trans, which really delayed getting the car back together. Also once it was back together the trans brake was touchy, but more on that later. Unfortunately because of the delays on parts, the trans not working 100%, and other things going on with life (mainly me getting married) we just were not able to get the car back out last year.
At that point we started planning for the new build up. We knew where we needed to make improvements, things we wanted to see done to the car etc. The basic plan at that point consisted of rebuilding the turbo kit, changing the fuel system, changing to a true stand alone, rewiring the car, and a few other smaller things. So now we can move on to the work!
12-2-11
We started work in December before the holidays. Chris had already started ordering parts and material by then. First things first, he decided early on that he wanted to stay with an air to air intercooler, but it was time for an upgrade. He also wanted to make sure that it would be future proof somewhat. After looking at the options, we decided to get a core and make the end tanks ourselves. He went just a little bigger....
I had also bought him a lightweight steering column and quick release from Mid West Chassis, and also a rear firewall from Wolfe racecraft. For some reason I dont have any pics of the rear firewall, but here is the column
Compared to the stock one with a quick release
And installed, dont worry we have a good amount of work left to do in there
We pulled the trans so we could send it out for a proper rebuild.
We also pulled the motor so we could do some work on the engine bay, and make it easier to go through the motor.
12-16-11
All we really did this weekend was strip the engine bay. I decided to make a time lapse video of this, and here it is!
http://youtu.be/lLcR5pQKseQ?hd=1
Chris also pulled the dash and stripped all of the interior wiring as well. No pics of that though.
We had a bit of a break in there during the holidays. I kept doing things at my work though. This next batch is all cell phone pics, so excuse the quality.
I started by drawing up a design for the intercooler end tanks.
Then we made a set up out of some cold rolled sheet metal to make sure the program worked, and practice the bends.
Blank. No hole for the piping since there is no need.
Fits like a glove
This is starting to get BIG
Now that we knew the program was good, it was time to load up the aluminum and make the real parts. Here is the sheet of 1/8" 5052 aluminum loaded up into our PEGA turret punch press.
Here are the two 4" holes for the intercooler piping
And the final two pieces
Next up came forming
And all done!
Next up came cutting the stock 3 bolt flanges off of the truck manifolds, so I could weld on the new stainless steel V-Bands.
All set up in the band saw
And both cut
Here is how the flanges fit before welding
All prepped for welding, had to get that ceramic coating out of the way
AND welded.
1-7-12
That brings us into the new year. During that "between time" that I was doing the above at work, Chris was going through the motor and fixing little things. We pulled the oil pan, re-tapped the holes for the oil feed above the oil filter since one was stripped, cleaned it all up and gave it coat of paint, and also plugged the hole for the oil level sensor. He also replaced the rear cover and rear main seal since we suspected a small leak back there.
Once we were back to work, I got started on welding the intercooler. I was not able to weld the end tanks to the core though since Chris's welder just didn't have the power. I should be doing that at work this week. Here are a couple of pics of my bald head welding though.
First step was to weld the ends of the intercooler as per the instructions that came with the core.
Then I tacked the end tanks to the core, and welded the seams on the end tanks.
Here is the resulting weld, not bad for self taught and my third time welding aluminum
Then we set the intercooler in place to see if it would actually fit
And bumper on, the cooler is what is holding the IC
Just for the heck of it, here are a couple comparison shots with the old IC now that the end tanks are on the new one.
1-7-12
The following weekend we did some work to the motor. Now that the bottom end was all 100%, Chris got to work on the top side. He changed both head gaskets which were in rough shape after that year of abuse
I again decided to make a time lapse of us doing the passenger side head gasket.http://youtu.be/ckny-AfYUgI?hd=1
After the motor was back to 100% we put it back in the car and called it a weekend.
Next weekend we will probably mock the turbo kit up on the motor on the stand just because. We are also supposed to be picking the car up next Saturday, so I should have some pics of that up as well. That is all for now. Once we get the car back though the updates should be pretty steady.
Sean
Sean
Sean
