My build - Lots of pics
I am not sure what Chris and/or Steve want to see out of this combo. I think we want 1000+ at the tires, and mid/low 8's in the 1/4 with the 4 bolt heads.Sean
I think right now we are hoping that the block is machined and shipped in ~2 weeks (just a guess), and the motor can be together by the end of July or early August. Then we can get it all put back together, tuned, and track ready in another weekend or two. So probably mid to late August before we hit the track.
Sean
Sean
That is all for now. It came in this afternoon so all we got accomplished was setting it on the stand and staring at it. They will be taking measurements and starting on machining soon. I am going to try and get as many shots of the process as possible, and will keep the thread up to date. Now that the block is here things should start moving pretty quick!
Sean
For a first run block (this one is #27) the quality is far better than expected, I have seen a lot of first run castings that look much worse.
Over the next few days I will be cleaning up some casting flash, checking every threaded hole in the block, and taking measurements of everything before machining.
We are hoping to have this engine 100% complete and back to Chris & Sean by the middle of next month. In hopes that it can make it to BG for the LSX Shootout.
lol
