newb turbo Q
Old Jan 31, 2008 | 01:04 PM
melon07's Avatar
Default newb turbo Q
on most turbo's, their's a external mount for the wastegate.. but on most setup's i've seen here, you guys are putting your oil feel line there.. Where would you put the wastegate? I'm trying to get my whole setup figured out and that was just one of the things I was curious about.. thanks
Old Jan 31, 2008 | 01:15 PM
tt427ls1's Avatar
LS1TECH Sponsor
I dont understand what your asking?
Old Jan 31, 2008 | 01:34 PM
John_D.'s Avatar
My oil feed is over the "cartridge" area and the wastegate is on the pipe going into the hot side housing.
Old Jan 31, 2008 | 03:48 PM
Pat-Man's Avatar
Depends on if you get a turbo with an internal wastegate or not. Most use an external gate that is mounted near the turbo's turbine side (hot pipes). It can either be vented to the atmosphere or back into the exhaust.
Old Jan 31, 2008 | 04:12 PM
melon07's Avatar
in this photo, their's a 'diamond' shaped flange for a wastegate... right? but most people use this for their oil feed line. This turbo is a master power T70. would it have an internal wastegate?
Old Jan 31, 2008 | 04:15 PM
Pat-Man's Avatar
That's an oil passage. You'd run an external wastegate.
Old Jan 31, 2008 | 04:18 PM
Pat-Man's Avatar
Best pic of internal wastegate I could find:
Old Jan 31, 2008 | 04:22 PM
melon07's Avatar
so the oil line goes there... and the wastegate goes.... ?
Old Jan 31, 2008 | 04:28 PM
93formto98T/A's Avatar
On the actual pre-turbo exhaust piping with a flange near the turbine inlet...
Pat-Man's Avatar
Wastegate would go between the manifolds and the turbine housing (on the hot side). The wastegate is what controls the amount of exhaust gases the turbine sees coming out of the exhaust manifolds. It controls this via a loaded spring and diaphragm inside the wastegate housing. When the exhaust gas pressure reaches a certain point, the valve opens allowing exhaust gases to bypass the turbine of the turbo. This bypassed gas will either be vented into the air, or back into the exhaust stream out to the muffler/cat back/cutout...
Here is a very simple diagram:
Hope that helps.
Old Jan 31, 2008 | 04:33 PM
melon07's Avatar
alrighty, thanks guys
