Using my APS washer fluid tank as meth tank.... who can modify for me?
ok thanks JM, just LMK and i can shoot some paypal over for it!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Man Im not going to charge you for something like this. I need to make sure it is 1/4 quick connect. Will do it today. I have to sleep at least 4 hrs so I wont be spaced out tonight! Dam 12 hr shifts.
man, im just waking up. We're starting golf practice today for the college team and there is a foot of snow on the ground, good thing this driving range has heated tees!
I'll at least cover your price to ship it JM. Thanks!
__________________
Sounds like a plan
Hope you like dollar menu, hahahahhaha
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
haha, i saw that there is a nut inside so i can probably just take that out and fit it to the aps washer tank, haha. Anything special i should do to make sure i dont get any leaks? Thanks MM
__________________
Thanks, what do you mean when you say set up for 8 hours before filling? Wouldnt i just add some around the fitting, install it and let it dry? Thanks!
__________________
#32
haha, u know what.. filling the tak never came to my mind whe i read it, lol. So simple.... Thanks Chad
__________________
#33
I am running the alky control kit with APS twins. I sent pics to them and asked what they thought about using the APS washer fluid tank as a reservoir, they did not recommend it. I got a different tank from them that requires relocating the battery, but it works well.
#34
I was going to do the exact same but relocating the battery is a few hundred bonez. I also contacted APS and they said the tank would be perfectly fine to use as the meth tank.... its stainless so it shouldnt be a problem at all.
__________________
#35
Also, in the pic above i see your meth nossel mounted in the silicone... how is that secured in there, i'd like to do the same since i'm MAFless as well. Thanks
__________________
#38
Nice, i dont see a problem with the tank starving as long as its not empty, i'll keep it full....
__________________
