Using my APS washer fluid tank as meth tank.... who can modify for me?
#42
Hello,
With my new APS kit, i dont have any room for my snow meth tank anymore, but the windshield washer fluid tank that comes in the kit would be perfect. Its stainless so it would hold meth perfectly, i'd just have to get it modified to fit up to the snow fittings. Any sponsors or anyone on here that sells snow stuff that could modify my washer tank to be used as a meth tank? LMK! Thanks!
No Space Under Your Hood...No Problem
It is becoming increasingly harder and harder to find space under the hood of today's cars. While many cars often do have the space to install a small container and pump under their hood this can be unsightly to some and take away from the car's appearance under the hood. Not to mention the installation can often times require the removal of the front bumper cover and other components to facilitate the installion. This can take upwards of 4-5 hours to complete.
Often time's space does not permit the use of an additional container under the hood. A common solution used by many is converting the vehicles existing windshield wiper fluid container for use with the water methanol/alcohol injection. This completely compromises the use of the windshield wiper feature as it will have to be disconnected if using a pure methanol shot or a mix containing high percentages of methanol.
We feel this is hardly a solution and simply a short cut used by others. Our trunk mount kit completely solves all of these issues by relocating everything cleanly in the trunk of your vehicle.
Unlike our competitors, each and every one of our trunk/bed mounts systems is pre-assembled and pre-wired by our own trained staff. Thereby making the installation quick, convenient and simple. Reducing the installation time from 5-7 hours to just over an hour to complete.
In addition, we hand test each trunk/bed mount water injection system to ensure it’s working properly before it’s packaged. Imagine spending an entire afternoon assembling a competitor's kit only to discover that it is defective! Or worse, a wasted trip and money spent having a shop do the installation for you.
#47
Be sure to check out our all-in-one rear trunk mount water methanol injection system.
#48
Additionally, water methanol injection is proven to work in addition to an intercooler enabling further lowering of air charge temperatures. It's not acceptable any longer to just run an intercooler and think thats good enough. We have cars running 20+ lbs of boost with turbochargers and centrifugals which are still seeing air temperatures just over 200 degree's after the intercooler. This is using the largest air-to-air intercooler they can fit in their front end.
By adding a water methanol injection system we can pull out an additional 80-100 degree's of heat after the intercooler. By combining water methanol injection with a highly efficient air to air intercooler we have been able to pull out nearly all the additional heat from the supercharger or turbocharger.
Just something to think about. There's many more benefits to water methanol injection then just lowering air charge temperatures.
#49
Here is my system
This is a link to the thread of what was done on my rig. You can't see the windshield washer tank but that is tied into the system also. I use mine for Open Road Racing so I am attempting to get it to last for up to 90 miles in the boost a fair bit. This gives me over 3 gals total.
https://ls1tech.com/forums/showthrea...ght=jeffyvette
Jeffy'
Jeffy'
