Does denser air give up more #Boost?
So would a dynometer be able to factor the added horsepower with the added boost if thats the case. I know the dynometer can facter in the air density to make a correction but it cant know you could be picking up denser air giving you more boost if thats the case, right?
On a supercharger, or anything else that is simply RPM controlled you will maintain the same pressure ratio/RPM at any altitude. But, since you're stuck with that pressure ratio, you are at the mercy of the ambient air pressure as the starting point.
Sea level you've got about 100 kpa baro (~14.7 psi), head up to say Eisenhower tunnel in CO, and you're down to low 70's high 60's kpa baro (~10 psi). You loose that 4 psi in the manifold with a blower. Been there done that at my last job. 12 psi in a cobalt SS in MI, 8 psi in CO at altitude
Air density has a direct relation on performance of your motor, and I don't see how it wouldn't also have a direct corelation to boost.
The runways in Denver are thousands of feet longer than say in NYC. Air density and altitude are why, as they need more runway to take off.
