KB Vs D1sc Discussion
Old Feb 24, 2008 | 07:51 PM
  #41
sciff5's Avatar
Originally Posted by DeltaT
The heat exchanger doesn't connect to the Whipple or KB. It is part of the A2W circulation system that connects to the heat exchanger cores (A2W) built into many PD manifolds. Is that what you meant?
Jim
Yes thank you. I've never dealt with or worked on a roots/twin screw blower so they are foreign to me
Old Feb 25, 2008 | 01:33 PM
  #42
Z06PSI's Avatar
Originally Posted by sciff5
Well my only real concern with the KB was the heat issue and now with the heat exchanger, which seems to be a lot easier to install than a A/A intercooler, I think all my issues are resolved. I still wish I knew how heavy this thing is. It looks huge, and has almost as much displacement as the engine in my daily driver.
Will deff need to cut a hole in the hood, which I already have but its a steel hood so I got a stock aluminum hood to replace it and I'll prob have to get a fiberglass/plastic scoop for summit
I still need to get the long tube headers to fit, I need to hook up the fuel system, and do a little more wiring and she'll be on the road.
Intercooler, manifold, and blower are 85 lbs. Just weighed it. Add another 20lbs for coolant, reservoir and other parts. Minus 10 for LS6 intake and other related junk that will not be needed. So right around 100lbs right over the k-member.
Old Feb 25, 2008 | 01:57 PM
  #43
sciff5's Avatar
Thanks a lot man. I guess thats not ideal for a car that will be seeing the track but like you said its 100lbs right in line with the front axle, compared to a turbo or procharger which would hang out in front of the engine.
That thing is a monster Lol
Old Feb 25, 2008 | 05:36 PM
  #44
Z06PSI's Avatar
100 lbs and double your N/A h.p. ...... Good exchange.
