HELP? how to check engine compression ?
Old Feb 15, 2008 | 09:03 PM
mike06tork's Avatar
Default HELP? how to check engine compression ?
anybody knows how to check the engine compression im try'n to check what compression will this engine combo will be at :
6.0 block with 4.000 std. bore
wiseco pistons with -11cc 4.000 bore
3.622 oem crank
6.0 317 heads oem not ported at all 71.2cc
with oem 6.0l head gaskets
scat I beam rods 6.125
so if anybody can check please if any body knows im trying to get the compression at 8.8:1 to 9.4 but i want 9to1 compression thanks for the help.
THIS WILL GO IN A turbocharged engine..................
Old Feb 15, 2008 | 11:01 PM
ninetres's Avatar
Should be about 9.4 or so. Too lazy to go punch it in a calculator
Old Feb 15, 2008 | 11:24 PM
mike06tork's Avatar
i checked in a calculator but i got 9.1 compression but i dont know if im doing it wrong can somebody check for me and let me know the engine parts im going to use are up their on top thanks ..................>>>>>>>>>>>>>>>>>
Old Feb 15, 2008 | 11:30 PM
waterbug1999's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
Old Feb 16, 2008 | 01:02 AM
mike06tork's Avatar
can anybody check for me ,thanks....................i dont understand this how to calculate im getting over 11.3 compression with -11cc pistons???????????????
MonochromeSS's Avatar
Looks to me to be around 9.1
Old Feb 16, 2008 | 01:27 AM
mike06tork's Avatar
so it looks good for a turbocharged eng. for 10-15psi on daily driver? 9.1compression.
Old Feb 17, 2008 | 11:31 AM
SonnyG's Avatar
Calculator suggests around 9.1:1 c/r.....10 psi high octane....dont risk it.....Any higher
Use water meth/boost cooler and keep it reliable.....
Dont go to insane with the timing.....More power also means more boooooooooom!!!!!!!
A thicker mls headgasket will lower your c/r...as well.....ahaaaaa
Did you think of that?I dropped a whole point in my tt project car./....
Old Feb 17, 2008 | 11:47 AM
Screamin_Z's Avatar
10lbs and 91 octane with a safe A/F and timing will be just fine. if ur wanting more, like 14lbs that's when I would mess with higher octane and/or meth.
9.1 scr is what I got.
Old Feb 17, 2008 | 12:33 PM
mike06tork's Avatar
Screamin Z you got 9.1 compression with my eng. combo on top or thats what you have on your ride and whats the size of the 6.0l MLS head gasket thickness?
