meth install
Old Feb 17, 2008 | 11:09 AM
ss01layinwheel's Avatar
Default meth install
I'm installing my new meth kit... is it ok to mount the nozzle so that it sprays the intake air temp sensor and through the MAF? my only worry if i mount it after the MAF then the nozzle is only about 3-4 inches from the throttle blade.
Old Feb 17, 2008 | 11:17 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
You should install it AFTER the MAF. It doesn't matter how close it is to the TB blade as long as it doesn't hit it. Needs to be before the TB tho.
Old Feb 22, 2008 | 12:20 AM
tomz28's Avatar
dont put it in front of the MAF that cant be good for it what kit did you get and what did they say about it
Old Feb 22, 2008 | 01:27 AM
kidcamaro98's Avatar
hasto go after the TB blade.....if you mount it infront of the MAF, your screwed.
what meth kit are you installing?
Old Feb 22, 2008 | 06:36 AM
ChevyChad's Avatar
No, it must go BEFORE the TB blade!
Old Feb 22, 2008 | 09:54 AM
ntimid8r's Avatar
Anywhere after the MAF and before the T/B is where it's supposed to go. I hope the guy gets the message after all these posts.
Old Feb 22, 2008 | 11:56 AM
I got the snow performance kit off summit.. sorry havent been on in a while. I've been porting my throttle and making up a custom mount for my tank and pump...I'll try and get some pics up when im'm all done.
Old Feb 22, 2008 | 08:46 PM
CALL911's Avatar
To clarify for some of these guys, yes, it needs to be AFTER the MAF, and BEFORE the TB. As close to the TB as possible while still being able to fully anodize into the air going into the TB.
Mine is isntalled in my elbow in the pic, right before the IAT sensor. The methanol is corrosive, thats why you don't want it before the MAF, not to mention if sprayed prior to the MAF it would screw up your MAF readings entirely. Eventually the meth will corode away at the IAT sensor, but they are cheep to replace, and even if using 100% meth instead of the reccomended by Snow Performance 50/50 water methanol mix, it would still take years before you should need to replace a IAT sensor. Here's my Snow Performance setup. It is injected through the red line going into my metal 90 elbow prior to the TB.
Old Feb 22, 2008 | 11:25 PM
ChevyChad's Avatar
Originally Posted by CALL911
To clarify for some of these guys, yes, it needs to be AFTER the MAF, and BEFORE the TB. As close to the TB as possible while still being able to fully anodize into the air going into the TB...
I think he means atomize
Old Feb 23, 2008 | 09:51 AM
87Lt1Monte's Avatar
I was just searching around .. and i think thats some funny **** Chad !! i think he wanted to say atomize also! Who said you have to be a ****** know it all to post on LS1tech!
Old Feb 23, 2008 | 11:04 AM
CALL911's Avatar
Lol, you know what I meant.
Old Feb 23, 2008 | 12:33 PM
ChevyChad's Avatar
I know, it just made me LOL when I read it
Old Feb 25, 2008 | 05:34 PM
GNXClone's Avatar
Default Why not to mount in front of the MAF...
I have a junkyard MAF I'm going to gut eventually, since I run SD mode. For grins, I put my alky nozzle in front of the MAF. I'm injecting denatured alcohol and water, about a 70/30 mix.
Take a look at the yellow plot, it's the MAF output in Hz. When the alky flows, it causes it to read so high that it rolls back over to zero. Or, it's just plain freaking out. One interesting note, the MAF always seems to recover immediately after the alky stops flowing.
