BMR turbo k member install got some ??
My PA racing one is made to fit the fram rail?/Its a plate on top verses the tube that BMR uses !I guess no diffrence one way or the other, but mine has a 18th inch plate verses a tube thats formed to fit the contour of a stock F body frame.Its almost like PA racing cut the bottom off of a stock fram rail and welded it to the tops of there K member!!
I'm thinking I'm going to have to get one of these for my 93. I'm going to try and fit a 4 inch DP down the passenger's side. I have one for my 98 and like it a lot. I'm going to try and notch the k member on that side by cutting out a slice, hammering, flipping it over, and welding it back in. Hopefully it will clear then. Otherwise I've got to drop extra money on another BMR unit.
So what the hell, CAN YOU FIT A 4" downpipe on the DRIVER side under the truck manifold like ive seen with OFI's kit ??????????? I think it was OFI if it was someone else's please correct me....thanks!
