BMR turbo k member install got some ??
Old 02-19-2008 | 04:08 PM
B18CYA's Avatar
Default BMR turbo k member install got some ??
I was wondering how many of you had problems getting this point into the frame? Its going to have to be ground down or drill out the hole to make it fit
Old 02-19-2008 | 04:19 PM
TS6's Avatar
TS6
No, its supposed to be like that. Just bolt it up.
Old 02-19-2008 | 07:04 PM
B18CYA's Avatar
FYI truck manifold kits might want to look into other k members. This one isn't clearanced the best for a 4" dp. Looks like it would work great for twins though
Old 02-19-2008 | 07:14 PM
W8N2SQZ's Avatar
Mine looked the same way on one of the mounting holes. I just bolted the sucker down and called it a day!
GLenn
Old 02-19-2008 | 07:22 PM
Reject's Avatar
any of yall have pix of the compressor area? would really appriciate it
Old 02-19-2008 | 07:29 PM
B18CYA's Avatar
you mean the other side? this is the ac side.
Old 02-19-2008 | 07:31 PM
Reject's Avatar
PM sent
Old 02-19-2008 | 07:40 PM
B18CYA's Avatar
got it.. no sorry and unfortunately dont have the compressor here
Old 02-19-2008 | 08:03 PM
Reject's Avatar
hopefully someone else might then thanks anyways
Old 02-19-2008 | 08:18 PM
Sideways240sx's Avatar
Do you think there would be room for a 4inch dp on the driver side?
Im not buying anything right now, but just getting ideas for the future.
Thanks, Chris
Old 02-19-2008 | 08:28 PM
Dragframe's Avatar
Thanks, Chris
I WOULD THINK!!! A 3 inch fits on the my lt1 down the drivers side nice. Some even have stuffed a 3.5"... this is on a STOCK K-member.
So with that I would think 4" would be a walk in the park
Old 02-19-2008 | 09:14 PM
Andy02Z's Avatar
I dont see why a 4" won't fit. My ofi setup fits a 4" with a stock k-member.
Old 02-19-2008 | 09:17 PM
Broke EF's Avatar
Where are you guys getting a 4" pipe through? We have a truck manifold set up, so maybe thats the issue? I know I didnt see any room (with the manifolds on) to clear a 4" pipe. Pics would be GREAT.
Sean
Old 02-19-2008 | 10:25 PM
B18CYA's Avatar
driver side
I will get a 4" on the pass side but will be a little tight
Old 02-19-2008 | 10:55 PM
Josh@KY-Turbo's Avatar
I am on the middle of a S91 build up using the turbo k-member. The. 4" DP will fit the passenger side with no big issues. Pics will be posted when I finalize everything.
Old 02-20-2008 | 02:45 AM
firehawk123's Avatar
I sent my turbo K-member to joel @ OFI to mke 5 inch DP for my OFI kit and it should be ready at any time i will send some pic for you guys when it get hear
Old 02-20-2008 | 07:47 AM
Reject's Avatar
are those extra gussets add on's from you or did they come like that from BMR already? all the pix i see dont have them
Old 02-20-2008 | 09:31 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
The K-member comes exactly as shown in his picture...
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 02-20-2008 | 09:34 AM
[QUOTE=B18CYA;8745248]I was wondering how many of you had problems getting this point into the frame? Its going to have to be ground down or drill out the hole to make it fit
It is not intended to fit in the frame rail. All you need to do is just tighten it up.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old 02-20-2008 | 12:05 PM
Reject's Avatar
nice nice! the pix on speedinc's website are alil old then
