Oil feed and return on STS
Old Feb 20, 2008 | 10:05 PM
dnm12's Avatar
Default Oil feed and return on STS
So I have been searching because I have heard of this being done but cannot find any information can you run a return like this:
anyone know fittings or parts that would be great, its that little thing right above the oil filter that gets in the way of installing LT's
Old Feb 21, 2008 | 10:36 AM
OUTLAWZ RACING's Avatar
No thats not the plate but im not sure where that is in the pic
Old Feb 21, 2008 | 01:24 PM
dnm12's Avatar
its a photo of a srt-4 that did it just wondering if anyone has this setup, i believe it is above oil level in pan
Old Feb 21, 2008 | 05:26 PM
koolaid_kid's Avatar
Wow. What a misleading lead in.
Over my best judgement, look on Vortech's site for putting a return line into the oil pan.
Next time, be more truthful about your goal, and you will get better responses.
Old Feb 21, 2008 | 05:56 PM
Superman09's Avatar
LS1Tech Sponsor
The fitting above the filter that you are speaking of is where you want to tap for your oil feed. . Just tap a fitting into your oil pan for the return. -3 or -4an for the feed and -10an for the return. Hope this helps
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 21, 2008 | 06:52 PM
dnm12's Avatar
thanks for the input so this is the return at -3 or -4AN
and my return should be tapped into the valve cover anyone got any photos of that placement?
Old Feb 22, 2008 | 07:38 AM
Dam skittles!!!! Thats why I dident know!
Old Feb 22, 2008 | 08:06 AM
PatrickF's Avatar
That is the feed!!! The fitting above the oil filter is feed, not drain!
Old Feb 22, 2008 | 08:32 AM
Correct, the oil filter is the feed. The return is into the top of the oil pan. If I can find the link, I will post it, but the Vortech site posts the way to do it. JFGI.
Here is the link to do the return line into the pan. Hope you can follow it.
http://www.vortechsuperchargers.com/support.php
Old Feb 22, 2008 | 09:00 AM
dnm12's Avatar
wow i meant to ride the feed, but thanks for catching that!!! for sure the oil feed and I am tapping the valve cover for oil return! Thanks everyone
