Power #'s from an STS on a LS6?
Anywho, it made 681rwhp/861rwtq on 15#'s with 110 racegas. And 560rwhp/728rwtq on 10#'s and 93 pump gas.
Regardless, safe is relative to how good the "package" is. Meaning, is the fuel system up to the task? Is the engine truly healthy? And probably most important, how experienced is the tuner?
So my advice would be, don't shop around for the least expensive place to tune it. Shop around for the most qualified. A couple hundred extra bucks with the right tuner, could very easily save you an engine and a lot less headache.
For whatever that's worth.
A crappy tune and /or crappy fuel setup will blow the engine at even 5PSI......so tuning and fuel are critical. Just my $0.02 Anywho, it made 681rwhp/861rwtq on 15#'s with 110 racegas. And 560rwhp/728rwtq on 10#'s and 93 pump gas.
And holey tq !!! Great numbers I have allmost the same stuff you got that looks like a EPP CAM grind
So what kind of numbers are you making with your setup? And is it a GT45R?
