torque!.. i mean dyno results inside
Awesome torque! I'm doing a larger turbo with TEC on my QMP kit Dave. Me and Jim (at TEC) went over my specs and found one that should support over 700rwhp. Its also water cooled. Cost is around $1100 for the turbo. The AR housing is .96 and fits fine. The only thing I don't like is how the standard 4 bolt turbo flange on the turbo doesn't align that well with the exhaust manifold hole. I'll have to port the turbo ex. inlet to match. I'm also doing a SS flex pipe on one of the waste gate tubes to allow for the heat expansion. Its too bad we can't fit a 3.5" or 4" downpipe in our cars.
J
rodent, you got any links for tec? i sure would love to 'try' one but i refuse to pay (again) for something i allready paid for once, catch my drift?
i will just have to see what rob and precision think about the whole thing monday..
i will just have to see what rob and precision think about the whole thing monday.. hopefully someone will accept responsibility and do me right.
http://www.turboengineering.com
Nice for me since its local and they know thier turbo's.
Mike
I do think exhaust restriction is a prohibitive factor.
So far I've only gotten up to a peak of about 9# (the meat of it 5 PSI at 5000 and rising) and put out 507 RWHP, 622 RWTQ.
When my setup got me 6# by 5000 RPMs, but rose no higher than 6#, I got 505 RWHP, 656 RWTQ. (TQ was higher because I punched it earlier, where there was more torque. TQ figure matches at the same RPM point.)
When I got 8 PSI by 5000 RPMs and no higher, I made 526 RWHP and 655 RWTQ.
In each case, the RWHP number was very flat. I had peak RWHP at close to that 5100/5200 RPM point and it did not drop off until about 6500 RPMs.
Once I get my setup where I can get 12 or 13 PSI of boost, I don't plan to take it any higher... or, if I max out these injectors. But, the dyno guys and I can see already, that exhaust restriction is going to be a BIG inhibitor for my HP number.
thats quite the accompishment. You've successfully tuned your car, on pump gas no less, to the limits of the T-63E QMP turbo kit. Good JobI realy don't think anybody will dyno too much more than you did with that turbo. If they do they'll probably be on the stock motor with the higher cr and higher octane.
If you get a turbo on there that will hold 18psi...look out!!!
yes the tq graph looks exactly like what the boost did. shot up then fell straight down.. somewhere around 18 at peak though i did 3 pulls turning in my mbc every time to no avail.
well the kit does have the log style manifold which is the same that george at turbotech admitted was the reason their kits are maxed out no matter the combination around 500rwhp..
but rob did make 700rw with his car, and i assume that that configuration is what spawned his production kit..but having not seen pictures of the details, cant confirm.
i do have a extra 02 sensor hole that i could put a pressure meter in, but i'd rather not foot the bill for that equipment ya know.. it shouldn't be my problem
i did make a misquote from precision and edited it.. they are confident the te-63 which i have will do 740 flywheel (not the t-63 which is 690)at 30psi.. i just have to get it there.. me not wanting to run 30 psi puts me at needing around a 71GTq for 15psi in the mid 600's rwhp. im not sure what the miscommunication was between them and qmp about their boost/output specs.
I'm thinking I should call Rob myself and ask for the T76 Ball Bearing turbo we talked about to replace the T74 Thrust Mount I got
-Geoff
Are you sure its not a controller issue. Did you try to set it at, say 10 - 12 psi.? Does it still spike, or is it steady to redline?
