2 Bar Map Sensor Issue
Old Mar 6, 2008 | 09:43 PM
mag-racer's Avatar
Default 2 Bar Map Sensor Issue
I blew out my 2 bar MAP sensor on my LS2 at the track last weekend. When I received the sensor, it did not come with a grommet, so I reused the stock one. Do I just need to get a new grommet, or do I need a new grommet and a way to hold the sensor in place better? Does anyone know the part number for this grommet?
Old Mar 7, 2008 | 08:41 AM
John_D.'s Avatar
The old grommet should be fine.
On my ls6 intake the sensor had some interference, an extra rib or tab on the sensor. I just trimmed it off so the sensor would sit flat like the stock one.
Old Mar 7, 2008 | 01:26 PM
mag-racer's Avatar
I went ahead and ordered a new grommet. The old one was actually torn near the top and part of the grommet is stuck to the intake. I am going to clean it up and replace it with a fresh one. It is a little loose on the FAST intake so I am thinking about using some Gorilla glue to hold it down even tighter.
Old Mar 7, 2008 | 01:55 PM
John_D.'s Avatar
Sounds like a plan.
Old Mar 7, 2008 | 10:42 PM
AFASTYZFR1's Avatar
sensor safe black rtv has worked for me
Old Jun 18, 2008 | 12:15 AM
058mydust's Avatar
Where did you order the grommet from? I have been looking here locally and no one seems to have it. Do you have a part number for it too?
