Rear Mount Turbo
my car at 9lbs of boost ran a 11.6 so it is obvious to us all that the common denomenator on your set up is YOU!!! i have full boost by 3200 rpm right where the converter flashes, its in the set up for any car, just like your fiero.
you can hate all you want but the facts are rear mount cars work, they are here to stay and nothing you say will change that. get over it
You are such a tool, TRUST me you don't want me to point him to this thread (he is a member here too), because you will get sooooo school in turbo and engine theory its not even funny. Look at how many members with 10 and 11 second cars are in this thread bashing you. I bet you are like 19yrs old.
And why should I drive an OFI car? My own 700+ wheel Hp car is just fine with me, plus it sees full boost if I sneeze on the throttle.
What converter are you talking about? Because nothing like that happens at 3200rpm on my Fiero.
They work, just not well.
let me give you the rest of the story seeing how you need specifics.
DA 2500 --- 2.1 60ft cant launch in boost due to no two step yet
now with your all nowing brain you can see the car is probably a low 11 -high 10 car with the correct set up to launch, not the kits fault, i havent bought the items to launch it with. also for your brain to chew on a built 347 doesnt produce more power actually it makes less power due to the low compression, i only run 9 lbs until i can upgrade the fuel system to handle the 12-15 psi plan on running. sweet dreams cupcake.
Roots superchargers are simply amazing. That's why every Cobra owner's 3rd mod is replacing it.
Of course it can be made better, find me an off the shelf kit of any variety that you cant add something here or there to make better. Sure the STS setup isn't perfect, but they don't advertise it as something its not. I think your car had something wrong with it, could be a million things, but the vast majority of us have working setups.
Making a blanket statement saying "rear mounts suck" is pretty easy to do without backing it up.
Do rear mounts suck? Of course not. They add horsepower. Is it going to be as effective as a huge front mount single on a race car? Well of course not.
Can they still make a ****-ton of power and make your sled move out pretty quickly? Yep.
If your Lt1 POS got waxed by a stock LS1 vette I'd say it's either time to admit you fucked something up or look into the DRIVER MOD.
Locking this one too, this topic has been covered many times before
