Cam lift for Boosted Motor
Old May 26, 2008 | 08:55 AM
CamaroSS19's Avatar
Originally Posted by JPH
Depending on what cylinder head you go with(sounds like a budget head u have in mind) there wouldn't be any need to go much over .600 lift range IMO. I would be more concerned with what Duration #s @.050, ICL/ECL, and LDA along with proper valve spring pressures your going to need for this combo. Your Duration # @.050 will dictate what amount of lobe lift the cam will have anyways, so start selecting from there, but .570-.600 lift range should be fine for your application IMO. Hope this helps.
Joe
Form what I have been reading I am going with a 228/226 .595 .595 116 .
I am going to run a 347 with a rear mount I think this cam is going to really help spool the turbo .
This is a good read . Cam selection is at the bottom of the page http://www.forcedinductions.com/help.htm
