Where, and how did you put your iat sensor in?
Old Mar 13, 2008 | 07:50 PM
  #41
Sideways240sx's Avatar
Originally Posted by reject
question but dose the sensor need to be in the air's way or is it good being that far up like yours?
The bung is almost flush with the inside of the pipe.. The sensor threads through so it is all the way in the pipe, but i didn't want the bung being an obstruction to airflow.
When i make the sensor finger tight it is all the way in the pipe, so once i tighten it down a little more it should be all good.
I also would believe that what ever temp the air is in the pipe, the temp will be, so i dont know if it has to be directly in the airflow. Just my guess.
Chris
Old Mar 14, 2008 | 07:10 AM
  #42
Reject's Avatar
sounds good enough to me!
man dude your almost finished
Old Mar 14, 2008 | 04:25 PM
  #43
DuronClocker's Avatar
Anyone know where to get that piece in aluminum? I'm running aluminum IC piping for my D1SC.
:doh: Nevermind, the page on Summit just popped up with them.
Old Mar 16, 2008 | 10:37 PM
  #44
Steve01SS's Avatar
BTW.. Autozone stocks the threaded 3/8 NPT IAT. Just look it up for the 91 GMC Syclone/Typhoon as previously stated. $15.99 in the store.. lol My buddy got one yesterday.
I've always wondered about the Mcmaster Carr warehouse.. Figured it would be a monster. They have multiple warehouses across the country. I get stuff from them all the time at work. I've ordered some odd-ball stuff (from raw materials, to fittings, end mills etc.. ) and it always comes the next business day. I love that place. I ordered a bearing at 7:30 PM EST and had it at 10 AM the next morning. Cant beat em.
Old Mar 17, 2008 | 12:06 AM
  #45
71chevellels1's Avatar
What happend if you dont have a IAT sensor in your turbo system?
Old Mar 17, 2008 | 11:31 AM
  #46
if you stay maf you need it. if you go sd I dont know. it is intake air temp
chris
Old Jun 25, 2008 | 03:51 AM
  #47
GH1086's Avatar
Do you need to get a bung if you're using the Syclone IAT sensor? Or do you just drill a hole and thread the sensor itself into the hole?
Old Jun 25, 2008 | 05:53 AM
  #48
Fireball's Avatar
you need a bung, unless your tubing is super thick and you can tap it 3/8NPT.
Old Jun 30, 2008 | 04:42 PM
  #49
GH1086's Avatar
Thank you.
Old Jun 30, 2008 | 09:08 PM
  #50
AFASTYZFR1's Avatar
Old Jul 1, 2008 | 10:10 AM
  #51
Big Bird WS6's Avatar
fast sells one that is threaded. i bought it to put in my system
Old Jul 1, 2008 | 10:11 AM
  #52
Originally Posted by frcefed98
remember this website, bookmark it. Makes looking for odd ball stuff real easy.
www.mcmaster.com
A quick look netted me this PN 4464K223 its stainless, but it'll weld to mild with no issues.
1.91ea.
edit or 4513K72, which is steel for a 1.02
but they areo pricey
Old Dec 2, 2008 | 06:56 PM
  #53
spdrcr7882's Avatar
is the tip of the IAT brass on the 91 syclone fitting? I just picked one up and on the stock IAT the tip is plastic, and on the one i picked up from autozone that comes on a 91 syclone it's brass, is this correct?
Justin
Old Dec 2, 2008 | 07:40 PM
  #54
I got mine from Auto zone, and it was brass. Harness plugged in, and it appears to work very well.
Chris
Old Dec 5, 2008 | 09:39 PM
  #55
koolrayz's Avatar
bookmarking for later
Old Dec 6, 2008 | 01:15 AM
  #56
extremetoy's Avatar
if im running a maf now and am going to a 2 bar speed density, will i need the IAT sensor... which wires off the truck maf are for the iat sensor?
Old Dec 6, 2008 | 07:44 AM
  #57
Frost's Avatar
Justin
Is the plastic connector gray or black?
I sell the threaded fast-response IATs and ECTs. The IATs are plastic tipped and brass bodied; the ECT is metal on the tip. Here are some images:
http://www.lsxtune.com/shop/product_...roducts_id/400
and
http://www.lsxtune.com/shop/product_...roducts_id/398
Old Dec 11, 2008 | 11:57 AM
  #58
spdrcr7882's Avatar
Just a heads up, I went to autozone and purchased the IAT for a syclone, and they sold me a coolant temp sensor, and I didn't realize it until I installed it and the plug wouldn't fit into the sensor. It sucked because I put the IAT in my IC piping put the pipe back on the car and after all that is when i realized it was the wrong plug. After that I took it back and told her they screwed up and she tried to sell me some other sensor that needed to be ordered and was like 30 bucks. Luckilyy a bunch of people posted the price they paid for their syclone sensor, so I was able to go off that to justify to her that she was tryin to sell me the wrong part again. In the end I got the right sensor and it worked great and i just dynoed 524 to the wheels at 11 psi.
Justin
Old Mar 24, 2009 | 11:49 AM
  #59
SuperC1's Avatar
www.mcmaster.com
1.91ea.
They also have them in aluminum 44705K318
