Best Supercharger?
other suggestions on that topic too are welcome. (or should i go with a turbo? supercharger sounds more fun from what ive heard)And my personal opinion would be the procharger.
First of all Whipple and KB do not make kits for the F Body. They do make kits for LS1's in Hot Rods, Corvette's and Silverado series. But neither will fit in the F Body. Search in the F/I section no one has installed either (into a F Body) so that is already out of the question. LM Speed has come up with way to make the C5 Maggie fit. Magnacharger does not make a kit specifically for the F Body.
What are you willing to spend? What power do you want to make? Procharger is a good product its a good general purpose supercharger. I had on in my C5. Its fun. But for me in the twisty roads of Kentucky here, it made its boost and power too high in the RPM's, same reason why I did not go with a high radical cam. Making peak power Torque or HP in the upper RPM's was not what I needed. Making power down low is what was "best for me". I think you get the idea.
TexasSignature2002 and i have alot in common.. I have a stock bottom end, with stock heads, and puts down 543rwhp!!!!
OR a turbonator
http://www.airpowersystems.com/fbody/tt.htm
Two of the posters above have prochargers making around 550 on stock bottom end. If my car wasn't a DD (and i wasn't scared to spray the 100 shot that i have installed), Id be right there with them for less money. I will be the first to admit that FI is the way to go if you want to go BIG, however it isn't for everyone. OP, H/C/N2O will reach your goals cheaper and more reliably IMO.
yea turbos are better in terms of numbers but a supercharger is a lot more reliable and procharger is probably the best supercharger out there for our cars IMO Two of the posters above have prochargers making around 550 on stock bottom end. If my car wasn't a DD (and i wasn't scared to spray the 100 shot that i have installed), Id be right there with them for less money. I will be the first to admit that FI is the way to go if you want to go BIG, however it isn't for everyone. OP, H/C/N2O will reach your goals cheaper and more reliably IMO.
But since the OP asked for which supercharger. Procharger has the best rep bar none.
Good luck on your build.
Link to our complete ATI ProCharger D-1SC/F-1A kit price. Give me a call this week for an even lower price on this kit! Bob
