STS Boost levels
Have you ever Logged a WOT run? I bet your IATs are in the 120-150 range and the ECU is pulling timing like a ****...
If I were you I would buy/do in order
1.Back the boost down to 5-6PSI for safety till you purchase more components
2. Front Mount Intercooler to drop your IATS to safe ambiet levels
3. Racetronix fuel pump or Twin GS340 Walbro pumps, one setup all the time and one boost refrenced if you want to get fancy
4. Get that sucker tuned, Bump the car to 8-9 PSI
5. Grab some 6.0 Liter heads, ported if you can with some Dual springs and you might as well do a small cam at this point, Now that you have your compression at 9:1 or so you could up the boost to 10+ if your bored of the 500+RWHP you will make on 8-9PSI and are willing to risk buying a new shortblock.
In reality Steps 1-4 should be done immediately before the kit was bolted on....
If you do decide to go with a two step right now I have a feeling your mod list will go like this
1. Two Step 200-400$
2 Up the boost to 10 PSI unintercooled, untuned, on stock fuel pump
Free
2. New shortblock and kleenex to wipe the tears away from sending a rod out the block or blowing a gasket 3000-7000
3. Buy a beater car and put around for 3-6 months untill you can have a new motor built with a new fuel system, Intercooler, and tune, that you choose to bypass earlier 3000-8000
good job bro. get that intercooler and then start to play around. 8 psi with intercooler is BY FAR better than 8 psi with NO INTERCOOLER
