Replacing Passenger side manifold on turbo
Paul
I can't wait to drive that beast when you get everything straightened out
I've always wanted to drive to a mid 10 second@130+mph full weight car
If I had a single turbo I'd be running either a 3.5 downpipe or a 4.0 down pipe if i could make it fit going intoa bullet and a turndown at the axle.
I really think you need to have a MPH goal for the car to make sure it's on track... Intmd8's custom single turbo LT1 is a 357ci and has dynoed over 700rwhp and gone 135mph on drag radials with a 3700 lb raceweight, so I think you should be shooting for similar mph which you can hit with less boost (he was 18-20) with a bigger motor.
-Jim
Unfortunately the downpipe is integrated which leaves no ability to put a bigger downpipe. I have no intention of creating a new manifold
or I might as well call it my kit and sell it
Since I could not post in the Locked thread, I will cut and paste Warbird's quote, and respond:
by Warbird;
"I have been told something similar and this could also be be part of the over-heating issue, this is related to the other side of the car. The passenger side manifold is simply to restrictive making the engine work harder thus generating more heat. I am replacing the passenger side with a customized header to hopefully equalize flow better. I hope this works because I am taking the car back too regularly to replace parts
I've seen Rob's original kit and there are quite a few differences (insert cutting cost here). The cross over pipe is 2 1/2" Rob's first had 3" pipe, the original car had a header on the passenger side we get a stock manifold
Paul" End Quote
I don't know where you get your information, but I really wish you would pick up the phone, or email me direct. EVERY SINGLE THING YOU SAID HERE IS WRONG! I mean, NONE of it is even close to accurate!!!
1. The passenger manifold is not too restrictive. At least not the '01-02 model manifold. Which is what we designed the kit to work with, and include it as well. PORTED even! However, ARE did not opt for that when they ordered your kit. They said they would supply the manifold and port it themselves!!!! That's why we gave them credit for it when they bought the kit! You and ARE definitely have some communication issues that need to be sorted out.
2. We tried a JBA shorty header on the passenger side and gained nothing. EGT's were the same, and therefore showed no difference in heat.
3. My car NEVER had anything but the STOCK '98, UNPORTED, restrictive passenger manifold when it made 707rwhp. Again, where do you get your bogus information???
4. My crossover pipe was only a 2" pipe!! Not a 3" EVER! And yours is a 2 1/4"!! My car now has the 2 1/4" on it as well, but not when it made 707rwhp.
Next on the list, is the topic of your crossover leak. You state that your crossover was leaking at the connection....why was it leaking? We supply stainless bandclamps, and it should not leak there. Nobody else's does. And how can you say that by installing a new shorty header, and fixxing the leak by welding the pipe, that the leak couldn't have been causing a boost problem?? Do you know how little of an exhaust leak on the pressure side it takes to cause a boost problem?? Apparently not. NOTE: THE HEADER CANNOT MAKE IT, as you said, "SPOOL FASTER OR HOLD MORE BOOST". It can only make it more efficiently flowing. And the shorty header doesn't do any better job of that than the stock, ported '01-02 manifold. Obviously, you spent money on a header you didn't need. All you really need was to fix your exhaust leak!
I'm really getting tired of being blamed for other's mistakes, and isolated problems. ARE ordered a "T-74 Tuner Kit" for your car. They supplied the passenger manifold, fuel system, plug wires, tuning, and installation. You have had problems that NOBODY else has ever had with our kit. Stop blaming me, and do some research before you jump to conclusions.
Thank you.
NOT!!!!!!!!!!
Please post all of the details from now on. It might save you some money.
