Help, BTC twins.
Old Mar 17, 2008 | 11:32 PM
LTCA's Avatar
Default Help, BTC twins.
Hi, I have finally gave up the alky burning solid roller smallblocks and decided to build a strong drag/street truck. I have a 2003 6.0L and I was thinking of this build, help me if anything seems out of place, the recent article in hotrod about that 5.3 in a fairmont wiht a mp70 making 602hp really inspired me.
6.0L
beehive springs
comp xe281r cam
twin gt45 t66 turbos, compressor: a/r .69 inducer 80mm-turbine: a/r .64 87mm wheel
a2a intercooler
meth inj.
victor carb. intake and ls2? msd box, or do i need the ls1/ls6 box?
the carb will be built by rupert racing, known for his alky carbs.
th400 trans, trans brake, 4200 stall, 9 inch rear, 4.30 gears, all left over from previous projects/race cars, going in a 91 S10. I was really just sketchy on if my research has led me to picking out good turbo's or if i should choose diff. ones, and any suggestions on a diff. cam would be appreciated too. I am looking to run around 10-12 psi on 93 octane + meth. inj. and possibly as high as 15psi on race gas, the motor may also end up being run off alky sooner or later. and help would be greatly appreciated and possible hp numbers are fun to read also. hope I didnt make a mess of my first post.
Old Mar 18, 2008 | 01:11 PM
LTCA's Avatar
anyone?
Old Mar 19, 2008 | 08:48 PM
LTCA's Avatar
bump...
