Procharger question
Old Mar 18, 2008 | 08:39 AM
WS-6_2002's Avatar
Default Procharger question
What is that spring loaded valve thing on the D1 kit? What is the purpose of it? And can the kit function with out it?
Old Mar 18, 2008 | 01:45 PM
blown454ss's Avatar
the bypass valve?
http://www.procharger.com/store/inde...d&productId=20
Old Mar 18, 2008 | 03:36 PM
Mark98SS's Avatar
It or some other bypass needs to be in the system so it will unload the boost off throttle.
Old Mar 18, 2008 | 09:28 PM
WS-6_2002's Avatar
I thought it was the bypass valve. Looks similar to the link but mine is more cheesy. I would like to take that off and put a blowoff valve instead. what do you guys think? I'll sound more cool and would probly function better than the cheap $hit that is on right now.
Old Mar 18, 2008 | 11:11 PM
SVC707's Avatar
no. you need a bypass valve not a blowoff valve.... two totally different things. just swap it and go for the mondo bypass
Old Mar 19, 2008 | 01:43 AM
WS-6_2002's Avatar
Would this take place of the procharger bypass valve? How would one go about installing this into the standard kit?
Old Mar 19, 2008 | 04:41 AM
EPP's Avatar
EPP
This is the current ProCharger Pr-flow bypass valve.
http://www.exoticperformanceplus.com....html?item=969
Here is the ProCharger Race valve for those running a lot of of boost. Bob
http://www.exoticperformanceplus.com...html?item=1261
Old Mar 19, 2008 | 09:23 PM
WS-6_2002's Avatar
EPP: How does this mount into the current system and what are the benifits of having this valve over the old standard valve? By any chace have yoou installed any weldon pumps into an F-body? if so where did you mount it?
Old Mar 20, 2008 | 04:56 AM
EPP's Avatar
EPP
The black valve is a better version of the older model it replaced. I don't see any benefit to it unless your old one isn't working.
The red race valve has the capability to release more air, so for higher boosted engines it places less strain on the blower belt and the blower itself.
We have not installed any Weldon pumps that I know of. Bob
Old Mar 20, 2008 | 11:31 PM
WS-6_2002's Avatar
How does the race valve sound when it releases the air? Is it a swooshing sound or like a blowoff valve? Are these valves on sale?
Old Mar 21, 2008 | 04:19 AM
EPP's Avatar
EPP
Thumbs up
It moves a lot of air, the sound it produces is going to depend on how much air it is releasing. You can purchase it at the link above. Bob
Old Mar 21, 2008 | 05:04 AM
ls 2 goat's Avatar
Picked mine up from Bob the other day...It sounds insane..there are some vids on here if you do a search..
Old Mar 21, 2008 | 05:46 AM
EPP's Avatar
EPP
Thumbs up
Awesome, thanks! Bob
Old Mar 21, 2008 | 09:45 AM
WS-6_2002's Avatar
What is the differance with open and close atmosphere?
