Help with Autometer elec. fuel pressure gauge please
Old Jul 23, 2003 | 09:00 PM
Procharged LM7's Avatar
Default Help with Autometer elec. fuel pressure gauge please
If so, is there any way you can look at the back of the gauge where the plug goes in and see which wires go where?
Last time I put the gauge in the pillar pod, all the wires except the red, pulled out of the small plug(the plug with a bunch of inputs on it), and I cannot see my fuel press
I just installed a new fuel press regulator thinking the pressure was staying the same
Even a drawing would be great. On mine, the gauge just pulls out of the pod(friction fit) otherwise I wouldn't even ask anyone to mess with it. I would appreciate it greatly. Sam
Old Jul 24, 2003 | 04:03 PM
Samba242's Avatar
Default Re: Help with Autometer elec. fuel pressure gauge please
I went and pulled mine out..... my attempt at describing it to you is below. Hope this helps.
(As you look at the end of the connector where the wires go in) There are 2 rows of 5 holes.
empty / empty / black / black / red
empty / empty / empty / gray / purple
If this doesn't help, I can try to take a picture and e-mail it to you. Good luck.
Old Jul 24, 2003 | 04:17 PM
wow thanks a lot for going to the trouble !!!
I emailed autometer this morning and they gave me the same descrip as you. Thank you very much for doing that! Sam
About to go tear it out and hook it back up .
