Superman V.3
Old Mar 29, 2008 | 07:49 AM
Superman09's Avatar
LS1Tech Sponsor
getting very close! Had one set back which i finished yesterday. I had to clock the compressor housing on the pass side to get the turbo outlet to fit in the K-member. What a Bitch! Well when compressing the snap ring, the snap ring came off. No way i could get it back on in the car so i had to remove the turbo. No way i was dropping my K again so i got creative..... Unbolted the manifolds and it dropped the assembly a bit enough for me to get the comp cover out of there, then with that gone it allowed enough room to remove the entire assembly out the bottom. I reclocked the turbo and installed the snap ring on the turbo then out of the car. Went to reinstall but with the comp cover back on, it wouldnt slide back up. So i removed the DP assembly and the turbo/manifold slid up and i bolted the manifold up. Then i mounted the DP to the turbo and i back in business without dropping the K! So today i finish running my lines and bolt up my AC and alt and go over small things. I'll get more pics up tonight!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 29, 2008 | 02:27 PM
MY99TAWS6's Avatar
So wouldn't it be easier to hold the bmr crossmember in place and then see if it had clearance before bolting it up to make this easier?
Old Mar 29, 2008 | 02:58 PM
n2ojunkie's Avatar
I use a tranny jack under the oil pan to hold my engine up. I think if I ever need to chang my o2's I would hold the engine up with that take out the bolts holding the K member in and lower it until I had room. I just did mine on the floor like yours with jack stands and its a whole lot easier than takeing the manifolds off. Should line right back up pretty easy, leave the motor mounts hooked up and just drop it a little.
Old Mar 31, 2008 | 11:57 PM
erk2581's Avatar
what the hell johnny it should be running by now...dont make me come up there when i get back from florida and give u a swift kick in the ***
Old Apr 1, 2008 | 04:21 AM
Datzneat's Avatar
Shame to cover up something so beautiful with a hood.
Old Apr 1, 2008 | 06:12 AM
Superman09's Avatar
LS1Tech Sponsor
haha, thanks Eric! Its close man. The APS kit is 100% complete now. The engine is complete. Just need to run some boost referencing lines, set up the PCV lines and mount catch can, mount tranny cooler in new location, install alternator and AC and figure out how to re-connect the steering shaft.... any tips here? Would it be easiest to unbolt the rack from the K?
Thats funny Datzneat, i appreciate the kind words!
__________________
Old Apr 1, 2008 | 10:28 AM
erk2581's Avatar
12.5 at best....
Old Apr 1, 2008 | 10:32 AM
erk2581's Avatar
btw, i have a race for you '04 CBR 600RR with a verrry experienced rider, its not stock, but its close, hes got an exhaust and some suspension work and thats it, should run high 10s low 11s...hes in my area so when u come down to pick me up on the way to woodward one time this summer we can run him...haha! oh and im in florida til thursday-friday morning, but if you think first start-ups gonna be this weekend, im making that drive!
Old Apr 1, 2008 | 01:47 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Lookin very good! Can't wait to hear some results!
Old Apr 21, 2008 | 07:56 AM
Reject's Avatar
Originally Posted by JMBLOWNWS6
Yawn! Are you done yet?
x2 !! hurry up apple seed!
Old Apr 21, 2008 | 12:39 PM
WHPLASH's Avatar
Who ended up doing your trans? I've had nothing but troubles with these 4L60e's.
Is it ready to go on the rollers? Looks great!!!
Old Apr 21, 2008 | 01:01 PM
  #32
4SFEDZ's Avatar
do you have to have a pump for the oil return on these aps systems?
Old Apr 21, 2008 | 08:31 PM
  #33
SS4Matt's Avatar
local guy who does some nice stuff. i believe he even did the trans or converter or both for the LSx shootout all motor winner
Old Apr 21, 2008 | 09:05 PM
  #34
venom ws7's Avatar
Very nice man everything look awesome.
are you done yet???
Old Apr 22, 2008 | 02:35 AM
  #35
peter@aps's Avatar
There's no oil return pump on the APS F body twin turbo system as the turbos are positioned for gravity drain.
Peter
Old Apr 22, 2008 | 06:21 AM
  #36
Superman09's Avatar
LS1Tech Sponsor
Mike Ridings did it. He is very confident in it and gave me a warranty on anything to back up his word. So we shall see how it holds up.
It is completed now. All thats left is to go over everything, make sure everythings tight, attach a few grounds, add fluids, and pray she works
W2W called me yesterday and told me they had a cancellation at the end of the week so if i dont run into any more issues, it might be on the rollers REAL soon!
__________________
Old Apr 22, 2008 | 06:23 AM
  #37
WHPLASH's Avatar
Good deal. Keep us updated. That car is a beast!!!
Old Apr 22, 2008 | 06:25 AM
  #38
Superman09's Avatar
LS1Tech Sponsor
Here are the latest pics....
__________________
Old Apr 22, 2008 | 06:47 AM
  #39
'00_Z's Avatar
I actually hope I see ya coming up the road behind me some time, I'm gonna block ya off and make you take me for a ride!! I just found out a guy I know out on the west coast went with an APS set up in his car and it is sick.
Old Apr 22, 2008 | 06:48 AM
  #40
Superman09's Avatar
LS1Tech Sponsor
Where are you located?
__________________
